View Full Version : Y block on fuel lines or not
JamesJ
04-19-2007, 06:56 AM
If I just run the fuel line into one of my rails and then run a crossover to the other and then a line out of it to the fuel regulator is that any different then running a Y-block then a line to each rail and then two lines to the regulator?
DeltaT
04-19-2007, 09:19 AM
Yes, in the first scenario you mention, the 2nd rail is not receiving an equal volume of gas, as the 1st rail has already consumed part of it. That being said, a lot of systems are set up that way, and unless you have something unusual, like a high-HP bosted system or something, you probably wouldn't notice a thing.
Jim
