View Full Version : 327 engine upgrades
rlplive
04-17-2007, 08:32 AM
Hey guys how's it going? I have a 69 camaro with a 327. This is what I know about the engine, it is bored .60 over, it has upgraded heads with z28 springs, I am not sure exactly what has been done to the heads. It has an edelbrock intake and a holley carb. It also has an hei distributor. I would like to switch out the carb and intake with something that will make this thing run pretty good.
It is going to have a t56 tranny and a moser 12 bolt with 373's. Any help will be appreciated. here are the cam specs
Operating Range: 1500-5500 RPM
Duration Advertised: 268° Intake / 268° Exhaust
Duration @ .050'' Lift: 218° Intake / 218° Exhaust
Valve Lift w/1.5 Rockers: .454'' Intake / .454'' Exhaust
Lobe Separation Angle: 110°
Thanks a lot
Ryan
Bow Tie 67
04-17-2007, 08:54 AM
I ran a performer rpm with a holley 650 double pumper on mine and she was very strong.
What carb and intake are on it now?
rlplive
04-17-2007, 09:19 AM
The carb is a 650 I believe, does holley make an 870? How do you tell for sure without knowing? Also the intake is an edelbrock but I am not sure of the model how can I tell by looking? I probably sound retarded but I am not much of a mechanic
Ryan
Shaker455
04-18-2007, 10:07 AM
Ryan,
What's the list number?
you'll find that number facing the front of the carb on the top right side...you'll see numbers.
Is the intake a dual plane....with the carb off the plenum will have a wall seperating the two sides.
some where on the intake it will have a number and a name in raised casting.
Jeff
rlplive
04-18-2007, 12:05 PM
wow I meant 680 sorry about the typo
Shaker455
04-18-2007, 01:08 PM
Ryan,
The 327 is one of my favorite small blocks...lov'em to death!...espically the eariler small journal ones that can rev 7 grand all day long!
What does your exhaust system consist of?
Here's my upgrade suggestions:
Performer RPM Airgap
Upgrade existing 3310 Vac sec 750 with downleg boosters, rear metering block and idle circurt.
MSD Pro-billet drop-in dist
rlplive
04-18-2007, 01:38 PM
I have some cheaper model dynomax headers, but I will probably upgrade headers and I would like to get this particular exhaust in 2.5" any thoughts? Also I know my 327 is an older one that uses the older style oil filter.
Shaker455
04-18-2007, 06:00 PM
Sounds like your on the same page...very good!
I saw a pic of your car on another post...very nice...your going to paint that?...looks mint now?
rlplive
04-18-2007, 07:55 PM
Hahaha it is far from mint, it pretty much needs all new sheet metal. It is going to be a frame off resto job. Thanks for all the help I am sure i'll have a ton more questions
Ryan
