View Full Version : 64 Studebaker Lark Daytona
Pages : 1 [2]
454bug
03-24-2011, 05:47 PM
VERY NICE PHILLIP!! :twothumbs
The car will be there after you get married... Make the bride happy. :)
puddin head
04-01-2011, 03:18 AM
Anything happening lately??
PhillipM
04-02-2011, 07:12 PM
Now that Arizona Bike Week is finished and my 14 hour days have stopped I can again focus on this. I just received the final rear suspension piece that I needed. I have had that front 3rd link mock up mount in there for a while and I just couldn't figure out a good way to make it work. So, I finally found a premade piece that I just have to weld up and attach to the frame rail. It came from one of these 4 wheel drive outfits that make fabrication parts. Once that is throughly tacked on I plan to move forward with the rest of the roll cage as well as borrow my buddies LS2 and continue mocking up the front suspension. The LS6 that I had in there is getting some upgrades and will soon sit in our F85..
ArtosDracon
04-03-2011, 06:56 PM
Glad to see it's not just gathering dust! This is really one of my favorite builds.
PhillipM
04-03-2011, 08:45 PM
Thanks Robert!
PhillipM
04-04-2011, 09:34 PM
Okay I finally found a bracket that I can modify and make work for my upper 3rd link mount. I started mocking it up tonight and though it still needs some work I'm actually jazzed about how it has started to turn out.. I may rotate the mount a little counter clockwise but to get my angles right I need it to be at the Z height it is at. At the moment I threw a piece of 2x2 in there and if that is what I need I plan to trim it down and smooth it out to look better.
https://static1.pt-content.com/images/pt/2011/04/IMG2011040400015-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011040400016-1.jpg
preston
04-05-2011, 07:14 AM
I'd try to put an insert into the frame tube itself so the bolt can go through the outerbracket and rod end and then thread into the bung in the framerail. That would be very stout. Alternatively I guess you would just gussett the bracket onto the frame rail which is probably what you were going to do anyway. Ideally of course its nice to have some adjustability on both ends of the link but for where you're trying to land it that's probably not very feasible.
PhillipM
04-05-2011, 09:13 AM
I was actually thinking that this would be fairly strong.. I do plan to try and use all 3 holes in this mount but you definitely have me thinking that I need to strengthen it up some more. I like your idea of going through to the frame rail but I agree that doing that and keeping the adjustability is would be pretty difficult.
Chevelle LT1
04-05-2011, 09:25 PM
Philip - Glad to see that work is progressing on your ride; it's been entertaining watching it come together thus far.
~ Jason
Motorcitydak
04-05-2011, 10:17 PM
That upper bracket will be more than strong enough. Those things can put up to some ridiculous amounts of abuse and it is over engineered for your application which is a good thing here. That upper will more than likely only see 2-3000 pounds of force be that in tension (acceleration) or compression (braking). If the geometry is good, burn it into place and move on. The only thing I see that alarms me about those pics is the amount of threads showing on the rod ends. How much is in the tube adapters? Are you planning to cut another longer piece of tube for that link?
PhillipM
04-06-2011, 09:10 AM
Steve, I think I missed that when I was tacking it up there. I need to cut it off to drill the rest of the holes to a larger size so before I put it back on the frame rail I will get out the jam nuts and make sure it is in as far as possible. I'm hoping to get a few minutes of work on it tonight :)
Motorcitydak
04-06-2011, 02:07 PM
Good to hear, I really like this build. You are doing a great job here!
PhillipM
04-09-2011, 08:28 AM
The other evening I was able to work on the 3rd link mount a little more, and for fun and something new to look at for a bit I decided to work on the cage a little more. Below are a couple photos..
https://static1.pt-content.com/images/pt/2011/04/IMG2011040600018-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG20110406000192-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011040800022-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011040800023-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011040800024-1.jpg
LT1Nova
04-09-2011, 11:02 AM
Nice tight cage work.
PhillipM
04-09-2011, 05:31 PM
Thanks! Putting the bars in is one thing.. Fitting the dash afterwards is another feat all together. We'll see how it goes.
454bug
04-09-2011, 06:59 PM
I'm glad to see you're back on the car!
Bryce
04-11-2011, 09:12 AM
nice work. I wish I had a tube bender!
PhillipM
04-11-2011, 09:43 PM
Bryce,
JD2 Model 3... they really aren't that expensive in the scheme of tools.
And now for a couple more tubes.
https://static1.pt-content.com/images/pt/2011/04/IMG2011041000028-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011041000027-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011041000030-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011041000032-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011041000029-1.jpg
Sorry about the shotty photos.. Forgot my camera at home and had to pull out the old crackberry.
PhillipM
04-11-2011, 09:45 PM
Thanks Ray! You know how it goes. Sometimes seems like you have a million other things that are getting in the way.. Thanks for following!
RS_Customs
04-12-2011, 06:36 AM
Bryce,
And know for a couple more tubes.
Ya they are great benders! I have the model 3 also, and David has the model 4.
Car is looking good!
Robert
PhillipM
04-12-2011, 11:26 AM
Trying to decide what size tube to run behind the dash.. Only specs I could find were NHRA and they call for at least 1.25 .120 DOM. Is that enough? Just don't think I have enough space to put a 1.75" tube back there..
Also, as you can see the main hoop in this car is set back. That is because of my height and desire not to hit my head on it. It is barely within SCCA spec for distance.. But because it is back so far I'm thinking I would like to put an X below the roof. What are thoughts on that?
63Duece
04-12-2011, 01:09 PM
i just went through ur whole thread.....wowawewuh!!! this is awesome!!!!
great car!
great work!
GL with the rest of ur build!!!
absintheisfun
04-12-2011, 07:11 PM
Glad to see this one back on track. I've been missing the updates.
PhillipM
04-13-2011, 09:54 PM
Thanks for the compliments guys!
So I'm working on fitting the dash to the down tubes. We had planned on Just Dashes refinishing the dash in the car but I'm wondering how I can tell them where the tubes will be. As you can see i opened up the hole on the drivers side too much and also pieces of the foam are breaking off. Maybe some spray foam just so they know the shape?
https://static1.pt-content.com/images/pt/2011/04/IMGP4483Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4475Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4476Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4482Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4481Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4477Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4480Medium-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMGP4478Medium-1.jpg
coolwelder62
04-14-2011, 10:00 AM
This is an awesome build.Great fab, work.Can't wait to see more.Scott M.
PhillipM
04-14-2011, 08:17 PM
Spoke with Just Dashs today. I think we've come up with a solution for the dash... Will show you guys more when I get a chance to start on that. Thanks for hanging in there. I am really hoping to start having some front suspension parts soon!! Fingers crossed!
PhillipM
04-21-2011, 09:31 PM
Okay guys, if you have been following our build you know that we have been really working to try and use the LS7 manifolds and mid-pipes. Well, I have began mocking up the steering and Houston... we have a problem.
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000043Small-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000045Small-1.jpg
As you can see the steering shaft runs right into the manifold!!! Such a bummer. If you guys have any ideas here that would be awesome! My Dad and I stared at this thing and after consulting with Bart on the phone the answer was to grab a pair of LS swap headers from Stainless works originally meant for a first gen Camaro. This particular set was originally meant for a car with a factory steering box but I think they will work well and provide plenty of room for the steering shaft as well as a motor mount.
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000048Small-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000049Small-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000047Small-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000046Small-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000050Small-1.jpg
https://static1.pt-content.com/images/pt/2011/04/IMG2011042000051Small-1.jpg
As you can see I'm waiting on my bushings to fully mount the rack and I'm pretty sure that I need to lift the front of the engine about 1/2" to clear the rack. That should be easy enough though.
As for motor mounts I'm now thinking of running these kits together. The first one takes it to a standard small block urethane busing and the second one takes it to the frame
https://static1.pt-content.com/images/pt/2011/04/LS104_02-1.jpg
https://static1.pt-content.com/images/pt/2011/04/c005in14-1.jpg
That second photo is kinda crapy but here is the link to the Welder Series site with the product.. https://www.welderseries.com/blog/online-store/chevy-motor-mounts-rubber-insulated/
If you guys have seen any other universal mounts for LS motors that you have been happy with or just look like they would be sturdy and well constructed let me know! Thanks!
PhillipM
04-22-2011, 09:58 PM
Worked on a few things tonight.. I stopped and picked up the bushings and tubing to install the rack. Everything looks like it should so that was nice.
https://static1.pt-content.com/images/pt/2011/04/IMG2011042200056-1.jpg
I also decided to change out the lower coil-over mounts on the rear to get it into double shear.. So far it doesn't look that nice but this is the best I could come up with. Any one have any cleaner ideas??
https://static1.pt-content.com/images/pt/2011/04/IMG2011042200058-1.jpg
Scary but the 1/2" bolt that was in there was already bent and we hadn't even put the car on the ground yet.. Crazy.
preston
04-25-2011, 06:56 AM
Its always been a tossup to me whether its better to put those bolts in double shear or keep them close to the bracket (always seems like putting it in double shear significantly increases the distance and therefore the leverage of the lower mount).
I don't know what your bracket looked like before but if they're built right the single shear is a non issue as the shock bearing butts right up against the structure of the bracket and the bolt has a ton of support. I always felt like a 1/2" bolt wasn't strong enough but when you look up the shear strength of a grade 8 1/2" bolt its pretty significant.
PhillipM
04-25-2011, 09:50 PM
Thanks for the insight.. I hear you on the distance between the mounts but I think I would still feel more comfortable if it were in double shear. I don't know. Maybe I'm worrying about it too much. Here is a link to what it looked like before..
https://www.pro-touring.com/showthread.php?79128-Coil-Over-mount-thoughts
Motorcitydak
04-26-2011, 12:00 AM
Take a look at these. I have em on my truck and they are great. You would just have to cut the edge straight, use a metal lock nut and you may have to trim down the bolt to make sure it clamps rite
http://www.ruffstuffspecialties.com/catalog/product_info.php?products_id=210
I also wanted to comment on your exhaust. I know that this is against the norm but if you are having too hard of a time with the steering shaft issue, maybe try using the passenger side manifold or shorty header on the drivers side and run the exhaust tube down and in front of the steering rack. Throw a heat shield in there somewhere too
aussietony
06-10-2011, 03:11 PM
Any fresh updates on the stude?
PhillipM
06-18-2011, 09:05 PM
I wish.. at the moment I am waiting on the damn spindles... Hopefully soon!!
cobragt
06-18-2011, 09:52 PM
Funny, I've got my spindles and control arms but I'm waiting on the damn springs.
64impala
06-22-2011, 10:17 AM
Very unique build! Keeps us updated
Ratty 46
06-23-2011, 04:04 PM
Kick-ass project. I always liked the lines of these cars ... I'll keep watching.
Ratty 46
PhillipM
06-25-2011, 05:42 PM
Thanks guys... I'm also waiting on a steering column that I orderd from Ididit through Prodigy. It was supposed to ship this past Thursday. Hopefully I will see it this week.
ponjohn
06-26-2011, 05:54 AM
What a fantastic build!!
Now do a Henry J next, you'll have two unique PT cars.
acegto
09-19-2011, 12:34 PM
Any updates?
PhillipM
10-01-2011, 04:34 PM
Asa,
No updates at the moment though I have been doing a lot of staring at the trans crossmember and the exhaust. We are completely rebuilding our 65 Olds at the moment for Power Tour 2012.. Once that is finished I will be jumping back on this car. My next things inline on this car are to get the front suspension finished up and move on to the exhaust, trans crossmember, steering column as well as work on a bunch of sheet metal..
Be sure to lookout for our Olds thread update soon. Alot of things getting done and will have photos to post in the next couple weeks.
85coupe50
12-20-2011, 01:08 PM
You have a very unique car you are building and it is amazing what you have done so far.
One off the topic question. Is Bart still selling the Bart Works SLA stuff for SN95 Mustangs?
rfalker1
12-20-2011, 02:42 PM
nice build!!!!!
PhillipM
12-20-2011, 09:08 PM
Hey Matt,
Bart is currently redeveloping the kits that he used to sell. He is making some upgrades to the design. PM me if you want me to have him contact you about them.
rfalker1,
Thanks! Rebuilding our Oldsmobile has been a TON of work as everytime I turn around it seems I'm hand building things.. I promise this car is not stalled out, I have been "blind staring" at a bunch of things these past couple months and I will be psyched when I can jump back on this beast. A couple surprises have still yet to be let out about this car!
workbenchracer
12-20-2011, 09:22 PM
Real COOL! Nice to see someone breaking the "mold"!
firemsam
12-21-2011, 04:27 PM
Awesome! i just read through the whole thread and am thoroughly impressed and inspired! great work and keep it up!
PhillipM
12-21-2011, 09:20 PM
Thanks guys!! You're getting me excited to get back on her.. Just need to finish up our Power Tour ride, and then it's on again:cheers:
acegto
04-05-2012, 03:31 PM
Its been awhile....get back on this thing or we'll think you gave up.
aussietony
04-06-2012, 03:09 AM
Hi phillip, Love the build i keep hinking bout this build wondering hows it coming along. Just off topic a bit how long did it take prodgy to get you your column? Ive waited in excess of 7 months now for sum parts to arrive and keep getting the run around!! Its frustrating the hell out of me. im nearly ready to get on a plane and pay them a visit!!!
PhillipM
04-08-2012, 08:47 PM
Ha! Don't worry. I've been really busy working on our Oldsmobile getting it ready for Power Tour. Should see some updates on this car around June or so..
PhillipM
04-08-2012, 08:50 PM
It did take a while to get the column from them, but my column was a custom size.. maybe a month to get it or so? I can't imagine Frank giving someone the run around. Good luck Tony, I'm sorry you're having so much trouble with it.
linkstar69
04-09-2012, 03:19 AM
Awesome littlecar.
aussietony
06-03-2012, 02:31 AM
Any updates on your build Phillip?
PhillipM
06-19-2012, 11:46 AM
Not much to say other then... Yup. Back on the Stude. :smoke:
https://static1.pt-content.com/images/pt/2012/06/GOPR0643Large-1.jpg
wellis77
06-19-2012, 11:47 AM
SWEET!!! Looking forward to your progress.
PhillipM
06-28-2012, 04:33 PM
Been working on getting the motor mounts fitted up as well as starting to look at the steering and clutch master mounting. Looking like some firewall work is in order to make it all look good and work right..
Drivers side frame stand..
https://static1.pt-content.com/images/pt/2012/06/20120625_202243_630Medium-1.jpg
https://static1.pt-content.com/images/pt/2012/06/20120627_212855_484Medium-1.jpg
ebay score.. Stock column mount
https://static1.pt-content.com/images/pt/2012/06/20120627_213026_975Medium-1.jpg
https://static1.pt-content.com/images/pt/2012/06/20120627_212943_389Medium-1.jpg
https://static1.pt-content.com/images/pt/2012/06/20120627_212832_374Medium-1.jpg
chunger
06-28-2012, 09:35 PM
What is that three cornered thingie in the middle of the steering shaft? What makes that? Is it a bearing/seal for the shaft?
acegto
06-29-2012, 08:29 AM
Sweet. Glad you're back on it. Love the motor mount stand. When things get in the way you gotta be willing to cut holes,right?
PhillipM
06-29-2012, 09:44 AM
Yup it's a firewall steering shaft bearing. I got it from speedway motors. I need it becuase of how many joints i'm having to use. Max angle on it is 25 degrees. They also make a two bolt version that has a max working angle of 30 degrees. I really need one with a 50 degree angle but couldn't find one. If anyone else has any ideas that would be sweet. Currently I will have to make a kick out on the firewall to get the bearing to a happy angle.
acegto
06-29-2012, 10:02 AM
With all the other fab youve done a kickout should be a cakewalk.
PhillipM
07-02-2012, 02:07 PM
Okay, got some time on the car over the weekend.. Here is what I came up with to solve the clutch master mounting as well as our firewall bearing mounting. The big problem with the bearing as you may recall was that the bearing maxes out at 25 degrees, and we needed closer to 50 degrees. So the solution we came up with was to step out the firewall with a piece of 3" 16g exhaust pipe that way laying around. Then filled it in, trimmed down and monted the bearing after drilling and tapping it. Think it all turned out pretty well. I didn't fully weld in the steering portion yet but I will get it tacked at least for now.
https://static1.pt-content.com/images/pt/2012/07/20120701_192837_891Large-1.jpg
https://static1.pt-content.com/images/pt/2012/07/20120701_192258_810Large-1.jpg
https://static1.pt-content.com/images/pt/2012/07/20120701_192021_257Large-1.jpg
https://static1.pt-content.com/images/pt/2012/07/20120701_192438_841Large-1.jpg
https://static1.pt-content.com/images/pt/2012/07/20120701_192422_950Large-1.jpg
https://static1.pt-content.com/images/pt/2012/07/20120701_192334_254Large-1.jpg
coolwelder62
07-02-2012, 03:55 PM
Very Cool,The Studebaker is turnin out nice.
acegto
07-02-2012, 04:32 PM
Told you the kickout would be a piece of cake...
linkstar69
07-02-2012, 08:22 PM
Nice fab
PhillipM
07-03-2012, 08:31 AM
Thanks guys! Yeah I was really concerned about how it would all come together and if it would look good. But, I'm really happy with it. I'm thinking about moving to the dash next. Decided to ditch the stock dash and just do one out of aluminum or steel.. Trying to work on things that I either already have or don't cost very much and a half sheet of metal isn't very $$ at all.
Glenn
07-04-2012, 01:08 PM
Your 'Baker is very,very cool .... I love the outside-the-box cars, Great job!
PhillipM
08-02-2012, 09:55 AM
Okay I'm really not even sure how long I've been talking about the front suspension... However, made progress on it last night. This is all just mocked up to get a measurement for the upper arm length that we need to build.
https://static1.pt-content.com/images/pt/2012/08/20120801_201720_604Medium-1.jpg
Tincup
08-03-2012, 08:03 AM
Nice build....
PhillipM
08-03-2012, 08:39 AM
Okay, got the upper and lower arms welded up last night..
https://static1.pt-content.com/images/pt/2012/08/P1000085-1.jpg
https://static1.pt-content.com/images/pt/2012/08/P1000083-1.jpg
srh3trinity
08-03-2012, 10:37 AM
Those are some great looking welds and cool looking fab.
acegto
08-03-2012, 09:10 PM
Not gonna lie...I watch for your updates religiously. This is my favorite car on the board.
454bug
08-03-2012, 11:18 PM
Hey Phillip,
I glad to see you're back on your project! That is some awesome fab work and welds!
BTW, it looks like you may have your steering angles taken care of but just in case it ends up giving you problems with the angles, don't forget about the optional "steer clear" product that I am using on my project. As you can see, they come in all different lengths and it may get the shaft away from the headers and eliminate all of the bad angles... :cheers:
If needed, here's a link to their website:
http://www.wizardsteerclear.com/
That front suspension is going to be REALLY nice! I am in the process of rebuilding my design as well to beef up the front spindles/hubs. They should be ready in about a month. Keep up the great work! :twothumbs
ArtosDracon
08-05-2012, 03:46 PM
So glad to see you're back on this project, been a favorite since day 1!
PhillipM
08-05-2012, 08:22 PM
Thanks guys! Sometimes it's hard to stay focused, but comments like that definitely help. I know the updates have been scarce lately but hopefully they'll come more consistently now. This week I did some reworking on our Oldsmobile to get ready for the Return to the Coast.
PhillipM
08-05-2012, 08:25 PM
Hey Phillip,
Those are cool Ray but WOW.. Pricey!
I'll keep an eye out for the changes that you make. At times I was questioning my decision to start from scratch but in the end I think it's going to be really awesome.
PhillipM
08-05-2012, 08:36 PM
Here it is with the upper arm mocked in...
https://static1.pt-content.com/images/pt/2012/08/20120805_112705_131Large-1.jpg
VicS
08-06-2012, 01:48 AM
Great to see Stude back on track, not that I'm biased with my Aussie 65 commander.
Vic
acegto
09-19-2012, 07:55 PM
Its been awhile phillip...whats up with the stude?
PhillipM
11-18-2012, 06:27 PM
Took some time today at the shop and we got the Studebaker pulled off the chassis jig. Oh man what a great feeling this is to see it on the ground.
https://static1.pt-content.com/images/pt/2012/11/photo1-1.jpg
https://static1.pt-content.com/images/pt/2012/11/photo2-1.jpg
I will try and get some more detail pictures uploaded soon.
Dave B
11-18-2012, 07:27 PM
Such a cool looking body style.
WILWAXU
11-19-2012, 01:13 AM
Car looks great on the ground!
coolwelder62
11-19-2012, 05:18 AM
Lookin Awesome.It's cool seeing peoject's built outside the Box.
deves2
11-19-2012, 02:26 PM
VERY cool project, I love it
454bug
11-19-2012, 04:37 PM
Hey Phillip,
The car looks great with the sheetmetal on!! :cheers:
acegto
11-20-2012, 06:40 AM
Thats what I'm talkin about!!! Total win.
PhillipM
01-14-2013, 06:27 PM
We've spent some more time on the car as of late.. sorry the updates are coming slowely but that's how it goes sometimes huh.. We got the front downbars tacked in along with the upper and lower coilover mounts. For good measure we threw on a Vette accessory drive to check the fit.
https://static1.pt-content.com/images/pt/2013/01/front1_zpse7d88390-1.jpg
https://static1.pt-content.com/images/pt/2013/01/front2_zpsa3d2b583-1.jpg
preston
01-15-2013, 09:13 AM
I'll join the chorus, loving the unusual body style lowered right and built tough. Having studied several upright designs and built my own as well I really like the straightforward and elegant design of those uprights.
PhillipM
01-15-2013, 08:00 PM
Thanks Preston, I appreciate the kudos. One thing that I've been brainstorming on but haven't come up with yet is a good way to safety wire the upper ball joint bolt. Becuase the bolt turns with the spindle I've been stumped but hoping someone out there has a good idea. Thanks!
jtomas801
01-15-2013, 09:06 PM
Could some sort of castle nut with a cotter pin work?
Edit: Is that the bolt head on top of the uca or is the nut on top? I am having a hard time seeing it.
Jon
preston
01-16-2013, 07:38 AM
I think the he's talking about the main UBJ, the bolt threads directly into the UBJ mount which looks to be steel ? You can either weld a tiny bracket onto the UBJ mount or probably better idea drill and thread bolt or screw and attach your safety wire there. Even though its just a another screw that could come undone you can loc tite a small bolt better than a big one. Or you could use a stud there and drill the end for safety wire to keep the nut from coming off. Of course the stud could still in theory back out but that is unusual and you can loc-tite the crap out of the stud more so than a bolt that you might want to take on and off a few times.
jtomas801
01-16-2013, 08:22 PM
I think he was talking about the UBJ too, I just couldn't tell for sure if it was a bolt or a stud. I am going to try Nord-lock locking washers on my car instead of safety wire, it's supposed to be the ultimate locking washer. After everything settles, the bolt or nut does not back off.
http://www.nord-lock.com/products/multifunctional-wedge-locking/
I also seen some testing with the original Nord-lock vs. all the other types of locking washers and adhesives. The Nord-locks seem to work well.
Edit: video link of vibration testing different lock washers - done by Nord-lock:
http://www.youtube.com/watch?v=o44XdbKGnHg
Jon
PhillipM
01-17-2013, 08:30 PM
Thanks for the ideas guys! I definitely want to do some sort of positive lock on there. I had been reading about the nord-locks as well but don't know anyone first hand that has used them in this sort of application. I was thinking about the stud idea as well Preston... I was thinking of doing that and then maybe cross drilling through mount to pin the stud with roll pin or something of the sort. I would probably still put locktite in there as well. Then I could just run a regular castle nut on top.
PhillipM
03-24-2013, 07:40 PM
Okay another small update! #1 I've got a set of Rushforth Whiplash's for the Stude now!! I'm really excited and think these are really going to make the car look great. I've got to get Jason to widen the rears to 12" but for now I get to still look at them on the car. I've finished 95% of the cage too. Just need to add a dash bar. Decided not to X the entire rear becuase I didn't want to be staring at it in the rear view mirror.. So, just did the bottom half with an X. I also keyed off the main hoop back to the rear section of the frame. After I've got the seats I'll do a harness bar as well. Let me know what you guys think.
https://static1.pt-content.com/images/pt/2013/03/C0E196F2C735460CAD355F2C169C942E15317000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/34C5CEE33A484AC38526E1425DA839F015317000-1.jpg
https://static1.pt-content.com/images/pt/2013/03/4A31AD95C2FC4911887847657E12994E15317000-1.jpg
Chevelle LT1
03-24-2013, 07:44 PM
Philip -
The car and workmanship continue to look great. Glad to see that the progress continues!
~ Jason
PhillipM
03-26-2013, 07:00 PM
Thanks Jason!
Bryce
03-27-2013, 07:36 AM
Right on! looking good.
PhillipM
06-04-2013, 08:05 PM
Just thought I'd update this quickly. I've been doing ALOT of welding on the car lately. So far I'm 3lb's of welding rod down! Can't believe how quick the TIG rod goes.. I should hopefully have more photos soon. Need to get a measurement for the driveshaft and hoping to start on the exhaust soon. Stay tuned for more updates!
linkstar69
06-05-2013, 04:50 AM
Great news
PhillipM
06-27-2013, 06:19 PM
Okay boys and girls, here are the fruits of all that welding!! This is the first time the car has rolled on its on chassis in 4 years. Here are the latest round of photos.
https://static1.pt-content.com/images/pt/2013/06/IMG_20130627_124255_777Medium_zps0d84a0f-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_20130627_124255_777Medium_zps0d84a0ff.jpg.html )
https://static1.pt-content.com/images/pt/2013/06/IMG_20130627_124237_680Medium_zpsc82e7d8-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_20130627_124237_680Medium_zpsc82e7d8f.jpg.html )
https://static1.pt-content.com/images/pt/2013/06/IMG_20130627_124439_469Medium_zpsf9521c8-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_20130627_124439_469Medium_zpsf9521c85.jpg.html )
https://static1.pt-content.com/images/pt/2013/06/IMG_20130627_124448_267Medium_zps6caf2a8-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_20130627_124448_267Medium_zps6caf2a82.jpg.html )
https://static1.pt-content.com/images/pt/2013/06/IMG_20130627_124506_434Medium_zps398cfe9-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_20130627_124506_434Medium_zps398cfe9c.jpg.html )
https://static1.pt-content.com/images/pt/2013/06/IMG_20130627_124457_443Medium_zpsc707aea-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_20130627_124457_443Medium_zpsc707aea2.jpg.html )
454bug
06-27-2013, 07:01 PM
Hey Phillip,
It's great to see some progress!! It's got a great stance! :twothumbs
LT1Nova
06-27-2013, 08:19 PM
Looks excellent. Keep it up!
MSTSFabbed
06-28-2013, 08:22 AM
Sick nasty awesome, Phillip!! I'm sure you're pumped!!
PhillipM
06-28-2013, 09:59 AM
Thanks everyone! Pumped is a great way to say it. Definitely checked a BIG item off the list. Updates don't come as often as they used to but hoping to just stay steady on her. One day worked on it is another day closer.
acegto
06-30-2013, 08:53 AM
Man I want a Studebaker, like yesterday. Your car is wicked, especially since it was a grandma car to start off. Gotta work on my pile now
shizzy
06-30-2013, 09:59 AM
Giddy up!
PhillipM
06-30-2013, 07:03 PM
Paul and I spent Friday night drilling out all the spot welds holding in the factory inner fenders.. We found out the passenger side had some work done to it so it was much tougher to get out than the drivers side. Once we got them out we mounted them on the car and spend Sunday building templates for the new inner fenders. These will bolt in and out and should provide plenty of room for the front wheels and tires. We also decided to throw the hood and doors on the car. The hood springs are torsion bars which is a big departure from anything GM was doing for hood springs during this time. I also lowered the back of the car about another 3/4". The doors and fender need some more time to get them adjusted and we are waiting for a new lower front valance from Studebaker International. Here are some photos..
https://static1.pt-content.com/images/pt/2013/07/photo1_zps324d9616-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo1_zps324d9616.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/photo2_zpsbdd8e69e-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo2_zpsbdd8e69e.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/photo5_zps80da6dd3-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo5_zps80da6dd3.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/photo5_zps7b2f6ca9-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo5_zps7b2f6ca9.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/photo1_zps87033318-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo1_zps87033318.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/photo3_zps72a844d1-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo3_zps72a844d1.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/photo1_zpsc533055c-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/photo1_zpsc533055c.jpg.html)
coolwelder62
07-02-2013, 05:09 PM
Look's Awesome.Very Differant.
PhillipM
07-03-2013, 09:23 PM
Started working on the radiator/core support. The way Studebaker mounted the fender and everything is a bit different than GM or Ford did. I currently cut out the original core support and have the fenders clamped to the frame. Once we get the fenders adjusted to the hood and doors I can finalize the core support location. Tonight we also ran out of TIG gas so that put a stop to fabrication for now. Hopefully we'll be able to get some more soon.
https://static1.pt-content.com/images/noimg.gif (http://s43.photobucket.com/user/pmckee/media/AA4E8888-521A-42F2-B2BB-D47B6307D880-3243-000001FC99E3F318_zpsab380b19.jpg.html)
Bryce
07-03-2013, 09:43 PM
looks awesome!
PhillipM
07-04-2013, 08:57 AM
Thanks a lot Bryce!
77tony
07-04-2013, 09:46 AM
Coming along nicely. Just luv these unique builds. Subscribed.:drive2: T
mitch_04
07-05-2013, 05:10 AM
I agree, great unique build. Almost makes a guy want a seperate section for non-typical PT cars...but then I suppose it would start becoming typical!
Motown 454
07-05-2013, 09:38 AM
Looking Good Phillip
ent72olds
07-06-2013, 05:38 AM
Phillip, don't be surprised if you see a few more of these Studes start to pop up here in the future! Be flattered!
PhillipM
07-06-2013, 09:08 PM
Thanks everyone. The kind words definitely help keep me motivated. As for other Studes popping up, that's a part of Hot Rodding I suppose. I'm always interested in how other guys would design and execute their projects so if I've persuaded someone to pick up one of these little guys then that's very cool.
PhillipM
07-07-2013, 07:54 PM
Today I continued to work on the front end. I also spent quite a bit of time lining up the doors, fenders, and hood. I'm running Delrin body mounts all around so I cut a pair of mounts for the new core support as well as got the rad/ac condenser/fan shroud mocked up. Really nice to just see more parts going on the car.
https://static1.pt-content.com/images/pt/2013/07/8803208C41E8403E83D35B09768EA54E53690000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/8803208C-41E8-403E-83D3-5B09768EA54E-5369-00000312DE14E8F5_zpsd5662260.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/D97711E7A4DA4100A9013CB21A26FD9553690000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/D97711E7-A4DA-4100-A901-3CB21A26FD95-5369-00000312E6852F05_zpsf724a120.jpg.html)
VicS
07-11-2013, 12:18 AM
Be flattered Phillip, these are a popular Stude in Australia but I can guarantee no-one has or is building one like yours. Like many, I have loved your project from day 1.
The 64 and 65 2 door Stude were almost exclusively Police pursuit cars in Oz.
PhillipM
07-13-2013, 08:00 PM
That's pretty cool Vic. I never new they were exported down there!
PhillipM
07-13-2013, 08:20 PM
Well guys, I've been busy. I had started on the core support without really knowing where or what direction I was headed. How was I going to mount the radiator? How will it be stabilized? Can I keep the over all weight of the unit light yet rigid? To my surprise things kind of fell into place and I'm really happy with the final product. I still need to final weld it as well as I would like to add some more holes to the front of it to allow air to enter the bottom 1.5" of the condenser and radiator. I've had some people ask me what brand of electric fan that I use and it is a Cooling Components. They have many different size shrouds and on this one I only had to trim 1" off each side for it to slide right into the back of the rad.
After having my new driveshaft made I realized that for some reason I ordered my 3rd member from Mark Williams with a 1330 yoke. Damn. I'm sure a 1330 would work for 99% but with some of the plans I have for this car I just didn't want to deal with the thought in the back of my mind so I got it swapped out for a MW1350 yoke. In preparation for getting the drive shaft mocked up I needed to cut out the rest of the floor in the way. I spent about 20 minutes making this new tunnel with the slip roll. I used 18 gauge for this because rolling 16 is way too much like a work out at the gym. I still plan to do any flat areas with 16 gauge to more closely match the original floor thickness.
Here are some pictures from the past few days.
https://static1.pt-content.com/images/pt/2013/07/948DD9171EE74F8ABC066C372F624B9A11044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/948DD917-1EE7-4F8A-BC06-6C372F624B9A-11044-00000678F88E16F5_zpsb122237d.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/4B99490563D64D658D78FA27A989F0BF11044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/4B994905-63D6-4D65-8D78-FA27A989F0BF-11044-0000067906066771_zpsab8fd318.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/D37230E6FE8F428DBAF3777EE911A5E311044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/D37230E6-FE8F-428D-BAF3-777EE911A5E3-11044-0000067913D2B628_zps52f04b40.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/FDFDBA79018247DFBDEA8C7E0B7F5BDF11044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/FDFDBA79-0182-47DF-BDEA-8C7E0B7F5BDF-11044-0000067929DAA23C_zps40c39461.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/07511348B10A4A3B9EEAE5AF6600538811044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/07511348-B10A-4A3B-9EEA-E5AF66005388-11044-0000067939215EC2_zps59a1fc72.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/190D76787000448EAD4FD0F59020A80611044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/190D7678-7000-448E-AD4F-D0F59020A806-11044-0000067941BBAE7A_zpsf5eced40.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/6ABE23BD631F4433864B5BD15731D1CE11044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/6ABE23BD-631F-4433-864B-5BD15731D1CE-11044-0000067952B66479_zpsa18748dc.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/9A62BA571FC04A038EECA3B3DC7E06E211044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/9A62BA57-1FC0-4A03-8EEC-A3B3DC7E06E2-11044-000006795B294B1C_zps8f9ac707.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/6306A45CCEF647D896C2DB2B9B1167DE11044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/6306A45C-CEF6-47D8-96C2-DB2B9B1167DE-11044-0000067962F1BD21_zps3e0090ea.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/B412F5045E4C494EAEA6C73247C3557411044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/B412F504-5E4C-494E-AEA6-C73247C35574-11044-00000679682021FA_zps45e00b8c.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/F46F340D2EF84FB080122E83DAFE335211044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/F46F340D-2EF8-4FB0-8012-2E83DAFE3352-11044-000006796F154049_zps2e2853e3.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/CED31526EB274595953B8050E8528FCF11044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/CED31526-EB27-4595-953B-8050E8528FCF-11044-000006797DBA03D8_zps430ab73d.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/2CA2784AE8E646B6B8DA1206B9B321A511044000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/2CA2784A-E8E6-46B6-B8DA-1206B9B321A5-11044-000006798C6AB5A0_zpse9ff80fc.jpg.html)
Bryce
07-13-2013, 09:26 PM
nice progress. Keep the updates coming.
PhillipM
07-13-2013, 09:32 PM
Thanks Bryce!
PhillipM
07-25-2013, 07:52 PM
Things are moving along slowly.. I mocked up my NASCAR oil cooler as well as started working on the front fender mounts and notching the rear cross member for the drive shaft. I've been kind of bouncing around on the car so I don't get bored. It all needs to be done anyways right?? I also scored an NOS front lower valance and got that mocked up in the last picture. Man it's a really nice piece.
https://static1.pt-content.com/images/pt/2013/07/AE29E542A62D4D41851DF604C27F5F5713480000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/AE29E542-A62D-4D41-851D-F604C27F5F57-1348-00000082B80E49B6_zpsf7cea1c3.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/8C5D1026880844A78CAA84EAD0F5F29F59890000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/8C5D1026-8808-44A7-8CAA-84EAD0F5F29F-5989-0000035312D6BF39_zps9f4d7e02.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/457BFBFECCCC44BAA260BC2F93B01FA759890000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/457BFBFE-CCCC-44BA-A260-BC2F93B01FA7-5989-000003531EC95A2D_zps717b0cb4.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/64E33C2C95D444E0B6A15C334543E30D59890000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/64E33C2C-95D4-44E0-B6A1-5C334543E30D-5989-0000035331DF79F0_zpsd9d41a91.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/F260D1C1BE224555818D3AA2323FE59313480000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/F260D1C1-BE22-4555-818D-3AA2323FE593-1348-00000082BF424A80_zps75237bc9.jpg.html)
https://static1.pt-content.com/images/pt/2013/07/0C6857D39A854D889111016044C1DBFA59890000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/0C6857D3-9A85-4D88-9111-016044C1DBFA-5989-000003530AEAAD5B_zps9874665f.jpg.html)
BPDRacing
07-26-2013, 09:41 AM
Such a cool car and awesome build. Thanks for sharing it with us.
acegto
07-26-2013, 02:15 PM
Awesome work Phillip.
Auto Rod Technologies
07-26-2013, 03:05 PM
Sweet little project!!
PhillipM
08-05-2013, 09:16 PM
Thank you everyone for the kind words!
I've gotten a little bit more time to work on the Daytona this past week. I'm at the point of mounting the radiator now that my intercooler is mounted. I want to touch on the intercooler because that is a part of this project that I have yet to talk about with you guys. I've had the twin turbochargers for the car for a very long time but haven't really mentioned it on here. The turbochargers are STS units that will be mounted where the rear seat was once mounted. I know there is a lot of good, bad, and ugly out there about remote mount turbos but I still want to try this out. People had asked me why I cut out so much of the rear floor and I think now that will most likely make more sense.
I had to cut off part of the inlets into the intercooler to get it inside of the core support that I built. That really happened because I swore that there was more room from there to the front bumper by man oh man how space begins to shrink fast when all of the systems start getting put in place. So far I've been able to get it in there but I'm really having to watch closely where things are going and how the systems are going to be interconnected.
https://static1.pt-content.com/images/pt/2013/08/D56FB73DE9164C218B5444D31934A34F20790000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/D56FB73D-E916-4C21-8B54-44D31934A34F-2079-0000012B79299BBE_zps7a81c680.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/A2BE690B6EEA420D8BC2C272DA1101E120790000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/A2BE690B-6EEA-420D-8BC2-C272DA1101E1-2079-0000012B9C151DDA_zps4f9a9f5b.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/CEC3ECA2A0C34C95AD36BE662A011C8D20790000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/CEC3ECA2-A0C3-4C95-AD36-BE662A011C8D-2079-0000012BA214909C_zpsf7b909f7.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/5E2C0CE4A5054B338A168C93B34B058320790000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/5E2C0CE4-A505-4B33-8A16-8C93B34B0583-2079-0000012BB59449AF_zps6c040f00.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/871208A9598249DCB4DDB57C0ECB0E7120790000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/871208A9-5982-49DC-B4DD-B57C0ECB0E71-2079-0000012BBCAE6B95_zpsfb8447bc.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/76665644D7834F11A25645CBCC577E3A20790000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/76665644-D783-4F11-A256-45CBCC577E3A-2079-0000012BC3739732_zpsa183d29f.jpg.html)
AusMarty
08-05-2013, 09:55 PM
I have yet to see one here in Oz.
I want one. HAHAHA!
PhillipM
08-06-2013, 08:26 PM
I want one. HAHAHA!
I have yet to ever see one running here either! I know there out there but let's just say where ever I go it won't be... "Oh, it's just another Studebaker Daytona with a tube chassis and twin tubos." LOL.
AusMarty
08-06-2013, 10:58 PM
That's pretty much every car here.
Except the Camaro's.
haha.
Good thing the states don't have our VT/VR/VP/VN/VS/VK/VX etc. commodores.
There'd be nothing interesting to look at.
PhillipM
08-11-2013, 08:44 PM
Got a chance to work on the Studebaker over the weekend. Like I've said before I have been jumping around a little bit to keep myself from getting too bored. There is so much to do on the car and I've been working on it for so long that I try to keep my brain from getting to bored or worn out. On Friday night I only had an hour or so at the shop so I worked on a lower radiator mounting solution as well as worked on an upper radiator hose. The portion of the hose shown here is our of a 78 VW Rabbit. Hey, what ever works right?
https://static1.pt-content.com/images/pt/2013/08/A3BC20B9B4194CE7A25DF0BF84B2737388570000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/A3BC20B9-B419-4CE7-A25D-F0BF84B27373-8857-00000439CECDB5AD_zpsa02ebaaf.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/772EF18A5AB248D9A5E08AD191F77D1C88570000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/772EF18A-5AB2-48D9-A5E0-8AD191F77D1C-8857-00000439DF35C275_zps6cb5298f.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/085A9C41A2D14C2D88890CA28913231788570000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/085A9C41-A2D1-4C2D-8889-0CA289132317-8857-0000043A5A42283B_zps66534b22.jpg.html)
Then, on Sunday my Uncle came over and gave me a hand with the inner fenders. They are about 85% there but I'm definitely happy with how they are turning out.
https://static1.pt-content.com/images/pt/2013/08/1CB0D108EAD54D6FB31F72D422AD418287420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/1CB0D108-EAD5-4D6F-B31F-72D422AD4182-8742-00000432536D356A_zpsd24e39fe.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/0CCA87F114D2426D9E290C2770069D8388570000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/0CCA87F1-14D2-426D-9E29-0C2770069D83-8857-000004391E83CB7B_zpsb2a4c3aa.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/5CA7818E07C44139B2314DEC1C5FD88A87420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/5CA7818E-07C4-4139-B231-4DEC1C5FD88A-8742-000004324B332133_zpse495934d.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/7F858C03A1EE463582D550991100829C87420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/7F858C03-A1EE-4635-82D5-50991100829C-8742-00000432447D189A_zpsc439eee4.jpg.html)
Then, for some blind staring I decided to throw the turbo's up into the back of the car. I think I might lower them down a little bit but this is really just to get an idea of how everything might fit/work. One thing I need to really think about is how to plumb the oil returns down into one container to pump it back to the motor. I would love to gravity feed them back to the oil pan but that's just not possible with where they are going to be located.
https://static1.pt-content.com/images/pt/2013/08/E6D88E2BDA484F9287E50C4243C1374387420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/E6D88E2B-DA48-4F92-87E5-0C4243C13743-8742-00000437858E2865_zps38a9e1c9.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/97B97D01DCB7459CAB375447123BFC2C87420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/97B97D01-DCB7-459C-AB37-5447123BFC2C-8742-00000437762F0331_zps52cb3185.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/9A425C3D4ABD4AF4896058958C3C896287420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/9A425C3D-4ABD-4AF4-8960-58958C3C8962-8742-000004327AB14C57_zps05748df0.jpg.html)
https://static1.pt-content.com/images/pt/2013/08/567E44EBDCFC4D19AFED7745A747282D87420000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/567E44EB-DCFC-4D19-AFED-7745A747282D-8742-000004378BF42EC6_zpseb4e5ac9.jpg.html)
Thanks for checking in on the project! I hope your projects are moving along too.
coolwelder62
08-12-2013, 09:41 AM
Look's Awesome.
PhillipM
09-01-2013, 08:27 PM
I haven't updated in a while but that's because we've been working one exhaust and turbo plumbing. Not very conducive to continuous updates so here is where were at right now. The 2.5" exhaust is plumbed back to the turbos and the 2" is plumbed up to the front cross member and then it transitions to 2.5" before going into the bottom of the intercooler. I've got the oil cooler mocked up into place and I'm ready to do some bead rolling on the pipes where the silicone couplers will be and then I need to do miles of finish welding on everything.
https://static1.pt-content.com/images/pt/2013/09/B3ECD021CFCE47DEB7592074F2D472C295270000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/B3ECD021-CFCE-47DE-B759-2074F2D472C2-9527-000005A315DDAB23_zps755d58c3.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/17F24347E4594682935F15DCB0DAE75A95270000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/17F24347-E459-4682-935F-15DCB0DAE75A-9527-000005A321531E1A_zps1326ab34.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/13EE0F9015974394B4C461A466F12D0815101000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/13EE0F90-1597-4394-B4C4-61A466F12D08-15101-000008E6B9C11EC8_zpsb5b7d5b0.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/3ECE1E7732184B8F846E3624653E224A15101000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/3ECE1E77-3218-4B8F-846E-3624653E224A-15101-000008E70B65A3E5_zps0e137fb2.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/EB9436236BDB49B191A7DEB7544103AE15101000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/EB943623-6BDB-49B1-91A7-DEB7544103AE-15101-000008E7010BF600_zps3c76cf48.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/AE2389E9C33F496997319DD04A10C40315101000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/AE2389E9-C33F-4969-9731-9DD04A10C403-15101-000008E6C9E694D4_zps4a781c26.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/32D86601006D4A16A447804FE0F28D3115101000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/32D86601-006D-4A16-A447-804FE0F28D31-15101-000008E64B6A2677_zps7efd0b4f.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/A3276671382F45EAA2B6BC68D44B619A15101000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/A3276671-382F-45EA-A2B6-BC68D44B619A-15101-000008E6E8AFE5C9_zps609e4570.jpg.html)
Bryce
09-02-2013, 06:24 AM
WOW, that looks great. Excellent fab work.
PhillipM
09-03-2013, 10:14 AM
Thanks Bryce! A lot of time consuming work. That's for sure!
injcted
09-04-2013, 03:11 PM
Badass build! Very talented!!!!! Keep updating
MSTSFabbed
09-05-2013, 03:30 AM
That looks awesome! So is the cold side all aluminum?
PhillipM
09-05-2013, 06:06 PM
Hi Stephen,
Yes per STS recommendation the charge pipes are 2" aluminum and then step up to 2.5" before the intercooler. I'm going to come out of the intercooler 3" a d up to the intake. I still need to block off the old ports on the intercooler and finish the mounts too.
Thanks for the compliments guys! I need to get the end pipes pulled off so I can bead roll them before I finish weld them. So much going on under there!
PhillipM
09-05-2013, 06:48 PM
So after doing some searching around for commonly used lower hoses in LS conversions I found this gates hose that looked like it might be really close. Well after trimming about an inch off one side it now fits really well. This is Gates hose 20450 which comes off something like a 1985 Jeep CJ7 in case anyone is looking in the future.
https://static1.pt-content.com/images/pt/2013/09/D1DEE4616A054DB2917FAE6F9CD7CC4218254000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/D1DEE461-6A05-4DB2-917F-AE6F9CD7CC42-18254-00000AD281FBC31F_zps1d28b2d6.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/CB5A25E23F284914891A8AB0B29811D418254000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/CB5A25E2-3F28-4914-891A-8AB0B29811D4-18254-00000AD2687D8DB2_zpsd6103108.jpg.html)
I also got a chance to start eye balling the down pipes after the turbine wheels. From my research it's basically best to go as big as possible here. Realistically that's going to be 3" for me. So, I picked up some 2.5 to 3" transitions from Summit and trimmed them way down. Here I've grabbed a left over 3" radius to start seeing what kind of room I've got. This is a medium radius bend and I've got some much tighter and also some that are larger radius so I should be able to get it to work no matter what.
https://static1.pt-content.com/images/pt/2013/09/9860F1B106704C7E988F17C2E86AE64918254000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/9860F1B1-0670-4C7E-988F-17C2E86AE649-18254-00000AD271F36A18_zps160f185c.jpg.html)
https://static1.pt-content.com/images/pt/2013/09/6A93842E3582491A971454857247DCAD18254000-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/6A93842E-3582-491A-9714-54857247DCAD-18254-00000AD276E7E2FA_zpsf0694c0f.jpg.html)
Another thing that I need to start looking at before the down pipes get too far back is my fuel tank situation. I've got the stock tank and it's in good condition but I really don't want to have a sump hanging down. I've also got an extra 69 Camaro Rock Valley tank that looks like if I were to cut about 4" out of each side might fit pretty well. Not sure yet what that would do for the total capacity so I need to do some math there on that idea.
That's it for now, more updates soon!
rustomatic
09-06-2013, 08:29 PM
You're doing crazy work--it's what makes this site worth returning to year after year!
PhillipM
09-07-2013, 05:56 PM
Thanks a lot! Maybe this thing will make it to RTTC? We'll see. It wouldn't be painted but could be good to shake the car down.
coolwelder62
09-07-2013, 06:19 PM
Awesome build happening here.I really dig the DIY stuff.!!!!
the dan
09-23-2013, 06:27 PM
man that flow of the tubes for the intercooler is awesome! pretty clean underside you have there. nothing to loop through to get the tubes where they need to go
Dc2x4drvr
10-22-2013, 05:23 PM
Wow, the fab work is awesome, cool car!
PhillipM
12-31-2013, 12:32 PM
Sorry for the lack of updates. The wife and I bought an older house and I haven't been in the shop for over 2 months. Hoping to have updates again soon.
Peanut1959
04-04-2014, 03:16 PM
I hope the new/old house is working out well. Any time in the shop with the Stude? It is an incredible build.
PhillipM
05-15-2014, 08:12 AM
Yes thanks for following up. The house is finished up and I've been working on our 65 Olds F/85 getting it ready for HRPT which is only 3 weeks away. Fixed a whole bunch of small things on it and some bigger things as well. Look for some updates on the Studebaker around the end of June :usa:.
CampbellshotrodsAZ
05-15-2014, 08:20 AM
Looking forward to seeing this thing done. I saw it in person years ago at some gathering at your shop during the night when we still had Cruising Main St.
PhillipM
05-22-2014, 12:16 PM
That's awesome Josh. That was fun when they were doing the Cruise on Main stuff. Then it kind of fizzled out. Hopefully one day the Studebaker will be out of the garage and get a little vitamin D. Haha.
PhillipM
06-25-2014, 02:25 PM
I thought since I got back from HRPT 14 and it's still kind of quiet around the shop I would mess around with this car a little bit. A while ago I sent some rear wheels back to Jason Rushforth to have him widen them from a 9" to a 12" for the back of this car. Well I got them back and they look killer. I also in the mean time picked up a low mileage LQ4 from another friend so I've begun transferring all of my accessories and oil pan over to that engine. Hoping to slide it and the T56 back into the car so I can continue fabrication. Here are some pictures..
https://static1.pt-content.com/images/pt/2014/06/IMG_3136_zps8df18825-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3136_zps8df18825.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_3126_zpsae6c1c17-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3126_zpsae6c1c17.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_3135_zps6fac4760-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3135_zps6fac4760.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_3125_zps5ab8b2a0-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3125_zps5ab8b2a0.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_3127_zpscea7fa00-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3127_zpscea7fa00.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_3138_zpsf14762e9-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3138_zpsf14762e9.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_3128_zps86b229e1-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3128_zps86b229e1.jpg.html)
I also had the chance to pick up another hood and drivers side door. Both of which were fixable but since I found these this will be much easier to start with.
https://static1.pt-content.com/images/pt/2014/06/IMG_2238Medium_zps76961f5b-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_2238Medium_zps76961f5b.jpg.html)
https://static1.pt-content.com/images/pt/2014/06/IMG_2239Medium_zps6049f213-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_2239Medium_zps6049f213.jpg.html)
PhillipM
06-25-2014, 04:12 PM
By the way, if anyone has some worn out 335 35 18s they want to donate I would love to throw some tires on these wheels!! Let me know. Thanks guys.
Phillip
driveit
06-26-2014, 10:55 AM
This is already and awesome car. I wan't wait to see it when it is finished.
PhillipM
07-14-2014, 09:54 AM
Just a small update. I spent that last few times at the shop working on the exhaust. I've fully welded the mid pipes and started welding the tail pipes and building rubber hangers so everything can move around a little bit. I think some of the exhaust tweaked during welding on the passenger side so I need to rework the tail pipe some. That's pretty normal in my experience of welding exhaust. Even if you take your time and jump around a lot your still just trying to minimize warping. Also, not sure anyone saw in the for sale section but I sold the Vintage Air front runner that was on this car. I just stuck out too far for this project so I decided to switch to a Corvette setup. Picked all that up today so going to throw those on and also start looking at some AC mounting. Would love to keep it down low for looks mostly.
PhillipM
07-14-2014, 09:58 AM
https://static1.pt-content.com/images/pt/2014/07/IMG_3225Medium_zps04788d79-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3225Medium_zps04788d79.jpg.html)
https://static1.pt-content.com/images/pt/2014/07/IMG_3227Medium_zps62131e76-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3227Medium_zps62131e76.jpg.html)
https://static1.pt-content.com/images/pt/2014/07/IMG_3226Medium_zps3ebdd3f5-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3226Medium_zps3ebdd3f5.jpg.html)
https://static1.pt-content.com/images/pt/2014/07/IMG_3228Medium_zpsa223fbdc-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3228Medium_zpsa223fbdc.jpg.html)
Dc2x4drvr
07-14-2014, 03:54 PM
That doesn't look like the 65...
PhillipM
07-15-2014, 01:07 PM
Ha! Still waiting on the insurance money from the Cutlass to fix it. I like how Paul smashes the car and then I'm having to hunt down the parts! Haha. Nobody can appreciate the stuff I bought because they aren't having to hunt for it. That stuff is harder to find than Studebaker parts.
OsirisGT500
07-17-2014, 05:52 PM
Ok this thing rocks first off. I'm digging the front suspension and spindles. How do I get some of this awesomeness?
circle mc
07-17-2014, 08:40 PM
Love this project! Nice build. Keep it up. Gives us hope on our projects.
PhillipM
07-22-2014, 04:13 PM
Thanks for the kudos. If you really are interested in the parts PM me and I can get you the information!
PhillipM
08-01-2014, 03:33 PM
Not much of an update... I grabbed a pair of 96 Firebird seats to use in the car. These are some of my most favorite seats. I know, not full on race but I like them. So here they are. At least now I was able to make engine noises! Oh yeah and they are super light manual only version. Double bonus!
https://static1.pt-content.com/images/pt/2014/08/0C8F7EB5B1804F0F9E8C722CB292685F_zpsmeqn-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/0C8F7EB5-B180-4F0F-9E8C-722CB292685F_zpsmeqnzgqv.jpg.html)
https://static1.pt-content.com/images/pt/2014/08/5E01114D06A14DD58EB0B3EA01C52DD3_zps4aai-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/5E01114D-06A1-4DD5-8EB0-B3EA01C52DD3_zps4aaiezxd.jpg.html)
acegto
08-01-2014, 06:11 PM
I love how the turbos are just hanging out behind the driver...No sleeper there! Keep up the great work Philliip
Dc2x4drvr
08-02-2014, 01:24 PM
Do they swivel haha
PhillipM
09-03-2014, 03:16 PM
I finished up with the tail pipes and even though I do have some more boost pipe work to do I'm kind of tired of working on tubing for the moment. So, I decided to move some attention to the fuel tank and trunk area. We've had this left over 69 Camaro fuel tank for a while. It was originally built by Rock Valley and is fairly well built. I've decided to start with it just because it's something tangible. I plant to cut off the sides and then cap them to fit the frame. Trying to keep it around 16 total gallons. The upper tank mounts are 70 Camaro pieces we bought here on the forum.
https://static1.pt-content.com/images/pt/2014/09/IMG_3535_zpsc7782f1b-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3535_zpsc7782f1b.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3534_zps3408379f-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3534_zps3408379f.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3532_zps728abd78-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3532_zps728abd78.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3531_zpscb4c6f72-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3531_zpscb4c6f72.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3530_zps3699ea3d-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3530_zps3699ea3d.jpg.html)
WallaceMFG
09-03-2014, 03:30 PM
Man I should call you to build the exhaust for my Chevelle! This car is going to be epic when it's done, hopefully I'll get to see it at one of the Goodguys shows in Scottsdale soon!
Dc2x4drvr
09-03-2014, 04:59 PM
Very nice work.
PhillipM
09-04-2014, 01:41 PM
haha! Yeah exhaust work is not fun. And this darn car has tons of it. I'd love to have this car at the show. One day it will be done. Just don't know when that day will be!
therobski
09-06-2014, 10:55 AM
Looks like your chipping away at it though. Outstanding Phil-therobski
454bug
09-07-2014, 08:19 PM
Hey Phillip,
Great progress and workmanship! The turbo setup is awesome.
Good to see progress.
Keep up the great work! :cheers:
OldStudeMan
09-08-2014, 01:03 PM
Hi Phillip:
My son alerted me to your build site. Looked at every post since start last night. Just now signed up as a member. Great plan and super craftmanship. I too wanted to do something different. I considered buying the car you now have several years ago. Don't know if you will be inspired or ticked to know that I am completing something very, very similar. My 1966 only 25 miles so far, now debugging and correcting issues. Would like to contact you direct & share but don't know how to proceed.
PhillipM
09-08-2014, 01:05 PM
Okay spent a bunch more time trimming on the fuel tank. I think I'm ready to break out the plasma and start cutting out the new pieces to weld it back together!
https://static1.pt-content.com/images/pt/2014/09/IMG_3563_zpsa62e1b6f-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3563_zpsa62e1b6f.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3569_zps1e87450f-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3569_zps1e87450f.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3572_zpsa015cd87-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3572_zpsa015cd87.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3571_zps33c6ec26-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3571_zps33c6ec26.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3577_zpsfb8c28a5-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3577_zpsfb8c28a5.jpg.html)
The darn SS straps that I have are too short so I need to make some different ones. Baffles me on how they would be too short but that sounds about right anymore!
PhillipM
09-09-2014, 10:11 AM
I worked on the fuel tank some more last night. First I took measurements for the length of hoses I need for the corner pick-ups from Vaporworx. After that I finalized and finished fabricating the stainless steel straps. I started with some longer A-Body ones and trimmed and recreated the one end but 2" shorter. Once they were in there I noticed that the tank was pulled up about 5/8" closer to the body. So, I did have to rework a little bit of my side templates to create a little bit more space between the frame. Other than that it wasn't too big of a headache. Maybe more of a bullet dodged?
So, I had originally planned to use my plasma cutter to trim out the new panels but man I didn't realize how under powered our plasma was against this 14g 304SS. So, I decided to throw a new blade into the band saw and just trim it out that way knowing that my new bi-metal blade probably wouldn't last long. However, it trimmed right through without an issue. We'll see how long it lasts though. Here is where I left off, with 1 side mocked up.
On a side note I was disappointed to see that Rock Valley doesn't purge or use Solar Flux in their tank fabrication. I'm not sure if Ricks purges their tanks or not.
https://static1.pt-content.com/images/pt/2014/09/IMG_3591Medium_zps9073378b-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3591Medium_zps9073378b.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3592Medium_zps64052a31-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3592Medium_zps64052a31.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3588Medium_zps6dca3ef6-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3588Medium_zps6dca3ef6.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3589Medium_zps0e4ba179-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3589Medium_zps0e4ba179.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3596Medium_zpsd66b1a55-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3596Medium_zpsd66b1a55.jpg.html)
PhillipM
09-09-2014, 06:51 PM
Hi Phillip:
I sent you a PM. Check your in box.
PhillipM
09-15-2014, 09:38 AM
Okay I know all these photos of the fuel tank getting modified probably aren't the most interesting to look at.. Haha. But Here are some more photos. I've got both side panels mocked into place and fitting really tight. I'm currently still making more pieces but until the corner pick-ups come in from Vaporworx I won't be able to tack anything else together. I've also got the original fuel tray cut out and the new Vaporworx Retroworx tray mocked into place. It BARELY clears the span of the old tray. In fact I might add some material on both sides just to give me more to weld to. Front and back are good. I've also been blind staring at how I want to do my fuel tank vent line. I've really been entertaining venting it out of the top of the fuel filler neck. Unless anyone has see issues with this. I also need to get my carbon canister ordered so I can decided where that will mount. Then I can make sure the vent line is routed correctly. I will probably route it on the exterior of the tank with some stainless steel 1/4" hard line. Maybe weld some bungs to the tank to allow for some adel clamps or something.
https://static1.pt-content.com/images/pt/2014/09/IMG_3624_zps93f70a1c-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3624_zps93f70a1c.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3626_zpsf41ddb29-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3626_zpsf41ddb29.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3629_zpsad4ffe87-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3629_zpsad4ffe87.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3631_zps352d87c3-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3631_zps352d87c3.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3627_zpsf096ab97-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3627_zpsf096ab97.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3628_zps184e5e72-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3628_zps184e5e72.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3633_zps42745cce-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3633_zps42745cce.jpg.html)
https://static1.pt-content.com/images/pt/2014/09/IMG_3632_zps2d3ded76-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3632_zps2d3ded76.jpg.html)
PhillipM
10-25-2014, 12:20 PM
Thought I would post some pix of the fully welded tank. Back purged with Argon and all welded up. It's got corner pickups and a CTS-V fuel pump. This baby is ready for action.
https://static1.pt-content.com/images/pt/2014/10/IMG_3705_zps2ff87ff5-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3705_zps2ff87ff5.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/IMG_3706_zps96d0c54a-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3706_zps96d0c54a.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/IMG_3707_zpsc2b0132c-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3707_zpsc2b0132c.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/IMG_3708_zps6469380e-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3708_zps6469380e.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/IMG_3709_zps460d1cc8-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3709_zps460d1cc8.jpg.html)
https://static1.pt-content.com/images/pt/2014/10/IMG_3712_zps6fd628f6-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3712_zps6fd628f6.jpg.html)
JohnO'Neal
03-11-2015, 09:58 AM
Any updates?
therobski
03-11-2015, 10:51 AM
Will "Deer-hunter" be ready for the 2015 Pour Tour??
PhillipM
03-17-2015, 02:47 PM
Any updates?
Sorry John, no updates at this time. As Robski points out I've been working on our 65 Cutlass after my Dad hit a deer with it. Progress on that car can be seen here - https://www.pro-touring.com/threads/42548-Our-F85-Power-Tour-Project/page8
Once the Olds is back on the ground and finished I will migrate back to the Studebaker. Just seems like whenever I get going on it again something else pops up and takes my efforts. Granted, didn't need to mini tub the Olds but it will be worth it in the end.
PhillipM
03-17-2015, 02:48 PM
Sorry no. It will be ready for the '16 Tour though hopefully.
the dan
07-07-2015, 06:51 PM
You need some dimple died plates to tie that cage to the body :)
the dan
07-07-2015, 06:52 PM
I'm really impressed with this build. I wish there wernt so many generic bolt together built that didn't hide these gems. If I knew how to subscribe I would
PhillipM
07-21-2015, 03:03 PM
Thanks for the fine compliments Dan. I do have a dimple die set so that isn't out of the questions. Just trying to decide on how I want the final interior to look.
Subscriptions can be added at the top of the thread under "thread tools"
I've followed your build as well and am jealous that your are driving it. One day I'll drive this beater. I promise!
Motown 454
07-21-2015, 07:00 PM
My first time seeing the tank nice job!!
PhillipM
07-22-2015, 12:21 PM
Thanks Wayne!
Here are a couple more detail shots that I never posted.
Vaporworx corner pickup..
https://static1.pt-content.com/images/pt/2015/07/IMG_3653_zpslrlrrrjr-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3653_zpslrlrrrjr.jpg.html)
I also need to rework the neck, so, I've chosen to go with a late model style fill neck with the little stopper door and everything. At least try to keep the fuel from running down the back of the car! Haha.
https://static1.pt-content.com/images/pt/2015/07/IMG_3654_zpsozfm3kmc-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3654_zpsozfm3kmc.jpg.html)
https://static1.pt-content.com/images/pt/2015/07/IMG_3655_zpsvsyv2mxq-1.jpg (http://s43.photobucket.com/user/pmckee/media/Studebaker/IMG_3655_zpsvsyv2mxq.jpg.html)
09-23-2015, 06:33 PM
I had to browse through a few pages to catch up but it looks like it is coming along pretty good!!!
bread_and_water
06-28-2016, 06:21 PM
I know it's old but any updates on this? I'm currently building a much more mild PT style 1960 Lark. Awesome work though so far.
Peanut1959
06-30-2016, 10:01 AM
Tyler - Do you have a build thread going (here or elsewhere)?
bread_and_water
06-30-2016, 12:08 PM
Sent you a PM
dodgedartgt
07-08-2016, 06:02 AM
Oh come on Tyler. We all want to see. Share your build.
Mike in FL
bread_and_water
07-08-2016, 10:07 AM
Mike in FL
I started a build thread, link in my signature, I just didn't want to muddle up this one with off topic chit chat.
dodgedartgt
07-10-2016, 06:10 AM
Thnx Tyler,
Good to see it!
Mike in FL
BTW, love seeing everything available being utilized, even the little red wagon in photo #9, post #2... LOL Looks like how I work!
PhillipM
07-19-2016, 03:25 PM
Just got done building a 78 Blazer with my Dad. Have a few other little things I'd like to do but I have been looking at the Studebaker for a while. I think I'd like to lower the STS turbos down and try to get a back seat in this car. I'll be working on it soon though. Thanks for the interest!
Finished Blazer.. Build thread here: http://67-72chevytrucks.com/vboard/showthread.php?t=705252
https://static1.pt-content.com/images/pt/2016/07/IMG_7320_zpsowsny7o7-1.jpg (http://s43.photobucket.com/user/pmckee/media/78%20Blazer/IMG_7320_zpsowsny7o7.jpg.html)
andrewb70
07-19-2016, 05:46 PM
Awesome Blazer build!!!
PhillipM
07-20-2016, 01:35 PM
Thanks Andrew! Trucks are super hot right now and we figured we should get in on a nice Square Body while they are still affordable. Haha. Never thought I'd say that!
Peanut1959
07-20-2016, 06:27 PM
Nice job on the Blazer! I especially like the choice of dog dish hubcaps.
PhillipM
10-17-2016, 09:08 AM
Appreciate it, thank you. Turned out really nice.
Patrick_K
02-08-2017, 11:27 AM
Any updates on this beast?
77tony
02-08-2017, 11:47 AM
Yes...updates please. T
PhillipM
02-14-2017, 01:15 PM
Haven't touched this car in a long time. At the moment we've got quite a few projects on the burner so this one has taken a back seat. However I've got some ideas on what I'd like to change. I think i'd like to get a back seat in this car now... So just stay with me and we'll have updates in the future for sure. - Phillip
jokeefe
05-24-2017, 05:23 AM
Phillip,
Just read through the whole thread and wow, was wondering if you had any updates? Would love to see this on the road.
John
PhillipM
05-24-2017, 08:30 AM
I'm sorry. I haven't touched it in a long time. I'm really struggling with how "race car" it is. The older I get and the more I realize how I really "use" my cars, i'm afraid I've gone too much towards the race inspired side of things. While I ponder that I think about lowering the turbos down in the back so I can get a rear seat back in the car. I'm thinking of redoing part of the cage so it's not so intrusive back there as well. Or I might sell it as is. Not sure really. I just love using my cars all the time with my wife and family and absolutely never go to the track. We'll see. If anyone has any thoughts feel free to post and let me know what you think!
Peanut1959
05-31-2017, 02:56 PM
Well, there's something about this car that spoke to you. I think you should finish in a more road-friendly manner so you can enjoy it for a while before you send it down the road. I'm sure the new owner will appreciate a more versatile ride, too!
PhillipM
06-30-2017, 09:18 AM
TO EVERYONE THAT MAY READ MY THREADS. AS AN AVID USER OF PHOTOBUCKET.COM FOR OVER 15 YEARS ALL OF MY PICTURES AND HOT LINKS HAVE BEEN NUKED. I DON'T KNOW IF THEY WILL EVER GET BACK AS I'M NOT WILLING TO PAY $400.00 RANSOM TO DO SO.
Thank you for your time.
Frustrated,
Phillip
CampbellshotrodsAZ
06-30-2017, 09:40 AM
I'm in the same boat. I have 2 build threads of pics held hostage. Screw Photobucket, they aren't seeing a dime from me. I will find a new photo hosting site and update each of my posts link by link rather than deal with such a crap company.
PhillipM
06-30-2017, 09:46 AM
Maybe someone will write a program to go out and fix it for you.. We'll see. Feels like Anglefire all over again!
PhillipM
09-27-2018, 03:35 PM
I don't have many photos to share yet, however, I did want to post on here that we are working on this car again. I had to go back and look through the thread myself to remember how for this car has come. As life goes on we have changing tastes and I would say I'm no exception. As we continue moving this car towards the finish line a few things will get changed. We will be redoing some of the roll cage so that I can get a back seat put back in the car as well as I'm currently working on a different turbo setup that will allow that as well. Once I have a bit more work done I will be sharing some more pictures so stay tuned.
injcted
09-28-2018, 06:24 AM
Cool build! Cant wait for update pics!
Peanut1959
10-01-2018, 03:05 PM
So glad to see you're back on it! I hope the back seat means you're after some serious street time. :D
Motown 454
10-01-2018, 03:12 PM
looking forward to your update.
ryeguy2006a
10-02-2018, 09:12 AM
I was actually thinking about this car not long ago as my grandpa picked one of these up a while ago and saw it a few weekends ago. Glad you are back on it.
STREETFIGHTER50
03-28-2019, 12:12 PM
Went through every page. What a bad ass build! Never see these Studs like this!
Peanut1959
11-15-2019, 05:36 AM
Update, please!
PhillipM
11-25-2019, 08:53 PM
Man I kind of teed that up and then didn't deliver! My wife and I had a baby earlier this year so working on anything has been very limited. However, the update is about 85% of the floor is back in the car and we have started fitting the seats as well as we've abandoned the STS rear turbo kit and are putting a single turbo up front. I traded the STS items to a friend for his bigger single. I also converted the car from a 3 link to a 4 link by adding another bar. Meaning we could go back to the 3 if we want to.. I'll try to get some more recent pictures uploaded over the holiday!
Phillip
Peanut1959
11-26-2019, 01:55 PM
Terrific! Glad to see it's still has life.
Motown 454
11-26-2019, 08:10 PM
I'm in to see it!
Peanut1959
05-27-2021, 10:24 AM
So...what's the latest on this build? Any closer to finished?
Reckn8
05-27-2021, 02:08 PM
It's my son's car. Father hood and house remodel has taken over for now! I look at it everyday parked over in the corner of the shop.
Peanut1959
05-29-2021, 08:40 PM
It's my son's car. Father hood and house remodel has taken over for now! I look at it everyday parked over in the corner of the shop.Thanks for the update! He deserves to take time to enjoy the kid while he's still young. He won't regret it! Wish him good luck on the remodeling project.
