View Full Version : wilwood master
$Mike70Z-28
04-09-2007, 10:29 PM
i was told that the wilwood master that the lines for the front brakes go to the back inlet of the master is this true and can i use the stock prop valve instead of the adjustable one from wilwood forgot to say that the prop valve is for disk/disk thanks mike
ProdigyCustoms
04-10-2007, 04:44 AM
The Wilwwod Master is front / front, rear / rear. As for the Prop valve, that depends on what prop valve and what brakes you have?
$Mike70Z-28
04-10-2007, 05:05 AM
thanks frank for the reply i have the 4 piston wilwood the prop valve i have is the one that looks like stock but its for disc im not to thrill for the adjustable prop valve i want more of a stock look thanks mike
ProdigyCustoms
04-10-2007, 05:48 AM
All you do it try it and if the bias is off, you can hide the Wilwood Prop valve by the differential at the hose that goes to the rear
$Mike70Z-28
04-10-2007, 07:01 AM
thanks frank good idea if it dose not work do i leave the stock prop and put the willwood in the back
