View Full Version : Rookie DIYer
72mach1
03-28-2007, 08:42 AM
I'm looking to convert my mustang from drums to disc's. I've never done it before and I'm wondering if anyone can give me a clue if this is something relatively easy to do with the kits on the market? Any special tools I am going to need? Trying to decide if this should go to a pro.
72SSAbody
03-28-2007, 12:57 PM
Are you wanting to go with a stock type of system or upgrade to a '94-'04 Cobra 13" PBR caliper system?
We have the brackets needed to do the PBR system. They use your drum spindles and hubs. No cutting is nessary and its a bolt on.
Joe
72mach1
03-29-2007, 10:01 AM
Wouldn't mind upgrading when I do it. Do you have a site I can see them on? Thanks.
72SSAbody
03-29-2007, 05:04 PM
I sent you a pm. :drive:
ProdigyCustoms
03-29-2007, 05:15 PM
You can do a Wilwood kit with basic tools. The only "specialty toll required in a saftey wire plier, which can be bought at auto parts or online for $30 or so.
Here are the instructions for your front kit and rear kit.
http://www.wilwood.com/PDF/ds505.pdf
http://www.wilwood.com/PDF/ds426.pdf
NOTE: the rear kit may be a different part number, but it is basically the same assembly instructions.
