View Full Version : Mini V8
23corner_blitz
03-22-2007, 11:58 AM
http://www.weberprecision.com/weberprecision1_015.htm
This page will describe the construction of a miniature eight cylinder engine I built in my home machine shop over the past few years. I still have a few small details left to finish, but the engine is running and almost complete. This was my first attempt at building a running miniature engine, I should have started with something a little simpler. I had a great time designing and building this engine and the first time it started was an unbelievable experience. I am going to take the engine back apart over the next several days to modify it for running on racing fuel or alcohol, I haven't decided which yet, I will be increasing the compression ratio by milling a bit more material off the cylinder heads. I will take pictures of all the internal components and post them here along with how I went about machining the parts and tooling.
samuel good
03-22-2007, 03:00 PM
Im sure you already know this but Ijust have to say it, dude you are BRILLIANT.
syborg tt
03-22-2007, 04:13 PM
simply awesome
okay why not build a little car to go around that motor.
merriman44
03-22-2007, 05:25 PM
Ha! How do you even do that?! Stewart Little can finally hotrod in a Chevy!! Thats amazing! It probably has more horsepower than my car too.
RobM
03-22-2007, 05:26 PM
have you ever thought about doing a full size engine?
i have always thought it would be cool to do a v4 with a big block chevy (454) specs.....
you could use alot of the already tested head designes, racing technology, pistons, rods, modify some aluminum heads.
think 12,000 rpm, 3.5 liter screemer in a 1000 lb sand rail. or VW bug or motor cycle
Bandit
03-22-2007, 10:55 PM
:jawdrop: That is one of the most amazing things I have ever seen! You must have a lot of spare time.
Do you think you could build one for me? I want to have the only R/C car around with a blown V8...:woot:
derekf
03-23-2007, 03:50 AM
Is this yours, or just a website you found?
Kenova
03-24-2007, 09:13 AM
Where's the video!?
Ken
23corner_blitz
03-25-2007, 09:36 AM
Website I found...
but thanks to everyone who said I was brilliant, you may continue doing so:thankyou:
