View Full Version : 67 Camaro Dash Help
1bad67camaro
03-16-2007, 06:55 AM
anyone know how the dash itself including the dash pad comes out of the 67 camaro?
paul67
03-16-2007, 07:59 AM
Yep , you need to remove the dash taking out the screws 3 at the top and 2-3 underneath you might have to lower the steering column , then open the glove box and remove the cardboard backer , remove the left and right hand trim that goes up along the windscreen to the headliner , remove radio and heater controls and the panel,now put your hand through the glovebox and run your hand along were the dash pad is you will feel some nuts theres about 8-10 all the way along ,you will need put hand through were the radio went and dash went. there about 3/8 or 7/16 there like a captive nut made from pressed steel .
Hope thats a help paul if need pics will post
