JEFFTATE
03-08-2007, 08:32 PM
Ok.I'm a big advocate of brake fluid flushing as part of routine maintenance.
That said, I recently replaced all three of the flexible brake hoses on my '69 Camaro. (original / stock brake system). They were showing some cracks.
When I flushed and bled the system ,The rear bled just fine, but I continued to get air from the front bleeders.( I usually use a bleeder bottle with a clear hose and sometimes a mighty-vac)
I finally realized that the air I was getting was being pulled from around the threads of the front bleeder screws.( like where they screw into the top of the caliper) So I put a little non-hardening pipe sealer on the threads and the problem went away. I had the front brakes bled in 5 minutes.
Just thought I'd share the advise with everyone.
