View Full Version : New guy here
EricButler
02-26-2007, 10:12 PM
Just thought you all needed another stang on here. So here is mine. Here is some pics and a run down on what is done to it. I am currently building another 67 coupe for a friend. Should be really sweet. I will post some pictures of it also with the progress on it.
342 STROKER.
SCAT STROKER KIT 5.4 FORGED H BEAM RODS AND PROBE FLAT TOP PISTONS.
302 BLOCK STANDARD BORE.
10:6:1 COMPRESSION.
NITROUS OXIDE SUPER POWER SHOT/100HP JETS.
MELLINGS HIGH VOLUME OIL PUMP.
PETE JACKSON "QUIET" GEAR DRIVE.
JAY ALLEN (Camshaft Innovations) CUSTOM GROUND TIGHT LASH SOLID ROLLER CAM
VICTOR JR.INTAKE
TOTAL ENGINE AIRFLOW TRICK FLOW TWISTED WEDGE HEADS, FULLY CNC PORTED 205cc INTAKE RUNNERS 60cc COMBUSTION CHAMBERS. 2.02 INTAKE VALVES 1.60 EXHAUST VALVES.
FLOW SHEET:
INTAKE: EXHAUST:
.100 71 .100 52
.200 145 .200 105
.300 219 .300 146
.400 273 .400 180
.500 305 .500 209
.600 315 .600 228
COMP CAMS 1.6 PRO MAGNUM ROLLER ROCKER ARMS,TRICK FLOW PUSHRODS.
HOLLEY 830CFM CHOKELESS RACING CARBURATOR, HOLLEY 110GPH HIGH PERFORMANCE MECHANICAL FUEL PUMP, WITH ELECTRIC RED HOLLEY STREET PUMP BACK BY FUEL TANK.
MSD DIGITAL 6 IGNITION, MALLORY DISTRIBUTOR, TAYLOR WIRES.
JET HOT COATED HOOKER COMPETITION 1 5/8 HEADERS 3inch FULLY MANDREL BENT DR. GAS X PIPE KIT WITH HOOKER MAX FLOW MUFFLERS.
FEL-PRO GASTKETS, AND ARP FASTENERS THROUGHOUT.
POWERMASTER 140AMP ALTERNATOR.
CUSTOM BUILT AOD WITH NON LOCK UP 3000 STALL CONVERTER
FORD 9INCH WITH 4.11 POSI TRAC.
CUSTOM MADE ALUMINUM DRIVESHAFT.
Suspension
FRONT:
Total Control Products front coil over suspension setup. 1 INCH FRONT STABILIZER BAR.
REAR:
5 LEAF REAR SPRINGS, KYB SHOCKS, 3/4 INCH REAR STABILIZER BAR WITH MIDOLYNE BUSHINGS, AND 1 1/2 LOWERING BLOCKS.
BRAKES:
BAER MASTER CYLINDER HYDRATECH HYDROBOOST.
FRONT: BAER TRACK SYSTEM, PBR DUAL PISTON CALIPERS 13 INCH SLOTTED,ZINC WASHED AND CROSS DRILLED ROTORS.
REAR: BAER TOURING SYSTEM, PBR SINGLE PISTON CALIPERS 12 INCH SLOTTED,ZINC WASHED AND CROSS DRILLED ROTORS.
WHEELS AND TIRES:
CUSTOM WELD WHEELS 17X8 IN FRONT. 17X9.5 IN REAR.
TIRES ARE MICHELLIN PILOT SX MXX3?S.
235 40ZR17 IN FRONT.
275 40ZR17 IN REAR.
https://static1.pt-content.com/images/pt/2007/02/DSC00832-1.jpg
https://static1.pt-content.com/images/pt/2007/02/butler209-1.jpg
https://static1.pt-content.com/images/pt/2007/02/Img0011-1.jpg
https://static1.pt-content.com/images/pt/2007/02/DSC01342-1.jpg
kmcanally
02-27-2007, 04:28 AM
Hi Eric and welcome to the site. Nice Mustang and I especially like the engine combo...any dyno numbers? There seem to be more and more Mustangs here recently.
EricButler
02-27-2007, 05:53 AM
Thanks Kevin, I have seen your car also. It is sweet!! I have never been a fan of black wheels on cars but wow I think yours is changing my mind. Yours looks really good with that combo.
I have some old dyno numbers but I have changed the Heads over to some Total Engine Airflow CNC ported 205 Trick Flow heads. I have also gone to a custom ground solid roller designed especially for my engine combo just this winter and I still have not even driven it. I also bumped up the compression a little. It used to make 340rwhp N/A and 345rwtq. Nitrous numbers were 431rwhp and 465rwtq. When I ran the nitrous on the dyno it was WAY off. It was so rich it filled the dyno room with black smoke so I knowthere was some tuning there to make more but really it runs incredible just the way it was.
Boulder69
02-27-2007, 06:09 AM
Damn man. You have the same name as I do. Seriously my name is Eric Butler. There are 2 Bob Johnsons on this board as well. Weird.
Welcome.
EricButler
02-27-2007, 06:58 AM
Welcome.
That is weird!! That is the first time I have ever come across any body with the same name. The internet sure makes the world seem smaller...
EricButler
02-27-2007, 08:33 AM
Here is a interior shot of the car.
https://static1.pt-content.com/images/pt/2007/02/DSC018381-1.jpg
George Manont
02-27-2007, 06:59 PM
Hi Eric,
Awesomely Beautiful 'stang you've got there.
" MSD DIGITAL 6 IGNITION, MALLORY DISTRIBUTOR, TAYLOR WIRES "
I have a plan to do the similar combo on my '65 , MSD + Mallory , as you have done. If possible, could you please do the wiring diagram so I could learn ?
Thanks, buddy.
George
https://www.pro-touring.com/forum/showthread.php?t=26890
Ralph LoGrasso
02-27-2007, 11:02 PM
Welcome to the site, Eric. Very nice mustang!
EricButler
02-28-2007, 06:36 AM
Hi Eric,
Thanks, buddy.
George
George,
Thanks for the kind words. I have also checked your project out and it looks like it will be awesome too when you get it done. Make sure to update me when you get further along I would love to see the progress.
Here is exactly how I have mine wired up. Now I will say that I have not really had to great of luck with my MSD Digital 6 plus. I am not sure if it is how I have it mounted but I had a MSD 6AL unit for years and years without any problems. It was also mounted in the same spot as my Digital 6. The customer service is great at MSD so that at least helps but I don't think it should have burned out TWICE already!!! I love the unit but I wish it was more durable.
https://static1.pt-content.com/images/pt/2007/02/MSDwiring-1.jpg
69rs
02-28-2007, 06:18 PM
Nice ride! Welcome. Just because there are two of you, don't act like the two Bob Johnsons!
George Manont
03-01-2007, 04:02 AM
Hi Eric,
Appreciate your diagram-sharing & advice. I'll take caution on the burning !
Thanks , Buddy,
George
bobbaganoosh
03-02-2007, 11:46 AM
Welcome, glad to have another Ford guy in here! It seems we are the minority around here. Your car is very nice, I've always wanted a 67-8 coupe myself.
EricButler
03-02-2007, 12:29 PM
Thanks. Yeah that is how it is when you have Ford. That's ok though because then it makes it that much better when you do see one that is set up right. I checked yours out on your car domain site. Nice brake set up on that!!
71dusterdan
03-02-2007, 03:38 PM
nice car eric, welcome, dont mind me and some of my frivolous posts, I really am almost normal. glad to have ya. Dan
6'9"Witha69
03-02-2007, 03:41 PM
welcome to the site. Nice looking 'Stang there.
