View Full Version : 67 full disk brake conversion
ProTour67CAMARO
02-20-2007, 06:02 PM
is it cheaper to buy a kit from a aftermarket brake site.
Or is there a cheaper method using a newer car (corvette)
anything anyone can provide will be of help. Pic would be great.
thanks again.
novanutcase
02-20-2007, 06:29 PM
http://www.kore3.com/proddetail.php?prod=10103
Tucks69
02-20-2007, 07:09 PM
I just installed a touring classics hybrid front kit and a kore 3 kit on the back of my 68 Camaro. I bought the rear as a kit, and built the front from different sources. By the time you chase all the parts down it would be just as cheap to buy a kit.
Mike
Modo Innovations
02-20-2007, 08:05 PM
Mike
I agree with Mike. I did the chasing down of parts myself and I should have just saved the hassle and bought a kit.
There are many different brake vendors here with alot of different kits to look at and see what you want.
Good Luck
02-20-2007, 08:38 PM
you just gotta know where to look. http://www.engineeredvelocity.com/
Gaslight
02-21-2007, 06:58 PM
If you can live with 2" drop spindles I have everything you would need. It all has about 1000 miles one it. I am running them on my 73 Nova right now. They have 11 inch rotors and 4 piston calipers from a 1LE Camaro. 400.00 plus shipping for everything.
Jake
BonzoHansen
02-21-2007, 07:27 PM
Jake
1LE are 12" rotors, no?
Gaslight
02-21-2007, 07:41 PM
My bad you're right. Brain fart!
Jake
bijanmaleki
02-28-2007, 03:34 PM
Maybe interested. Would I have to use a different master cylinder than the manual one from the drums on it now?
Taylor1969
03-06-2007, 10:55 AM
Here is what I did...
Front - total cost ~$1100
ATS Spindles
c5 corvette rotors, calipers and abutements
Rear - Total cost ~$500
Brp Bracket - $40
Brp Shock Relocation Kit - $150
Ls1 setup off of ebay - $150
Rotors, pads - $150
For about the cost of CPP setup I netted a set of ATS spindles and I have a parking break. I now need to get a 69 stingray manual master (~$25) and all new lines (~$250) and I will be completely done for about 2K total and have awesome stopping power.
Taylor1969
03-06-2007, 10:56 AM
Note -
because you have a 67 camaro you don't have to get the shock relocation kit which will save you another $150
