    Results 1 to 8 of 8
      Sep 2004
      San Antonio,Tx
      Q how is your automatic setup shifting wise?
      That is ... what mods did you make to how it shifts... are you satisfied... what would you change... Thanks
      Jan 2003
      Arizona
      I run a PCS electronic trans controller with a 4L60E. I have fine tuned the map to the point where it shifts when I want and how I want. If I want my 1-2 shift to occur one mph sooner at 13% throttle angle, I just go into the software and tap the arrows on my keyboard--left, right, up, down. Perfection.
      As long as I stay in the gas and have traction--my transmission is set up so that the car pulls like crazy at all wheel speeds and throttle angles.
      For situations where more control is needed (i.e. wheel hop, lost traction, auto-x, etc, I shift manually via my paddle shifter.
      ________________
      Steve Chryssos
      Houston, Tx
      Quote Originally Posted by streetfytr68
      $850 for the controller and harness? I would really like a more budget friendly solution. Are there any options that would put me under $500? I have no plans for paddle shifts or anything like that.
      Jan 2003
      Arizona
      Engine type? Gen1?, LT1?, LS1? LS2? If you have some sort of factory ECU, you can accomplish all of the automatic calibration (except manumatic capability) with tuner software such as LS1edit.
      ________________
      Steve Chryssos
      Houston, Tx
      It is a carbed 383
      Jan 2003
      Arizona
      Then it's $850. But worth it!
      ________________
      Steve Chryssos
      Jan 2007
      Bedford, PA
      what engine and transmission combo are you using or plan to use...
      Sep 2004
      San Antonio,Tx
      Quote Originally Posted by Jayco_Automotive
      It's a 383 making between 430 & 450 hp and about 460 to 475 torque in 3000 to 3300lbs chassis with 4.10s. I'm presently looking hard at 2004r with a full manual valvebody. For the control of a manual w/o the clutch (fading L. knee don'tch know). My reason are 3 fold : 1. it's lighter in wieght and has less rotating inertia. 2. it has better gear spacing. 3. fits the transmission tunnel w/o mods.
