Results 1 to 9 of 9
02-03-2007 #1
Starting The Transformation
- Join Date
- Feb 2007
- Posts
- 327
My tilt telescope steering column has slop in it, what shall I do?
Hi,
I have a 77 deville that has slop at the joint inside the tilt telescoping steering column. It seems like it would be tough to take it apart and get it back together so that the blinkers hazard and ignition all work right. Do you think I should try to fix it or maybe I should try to put a straight column in from something else? Thanks
