View Full Version : Rear LS1 Swap - BRP Brackets - Need help
Taylor1969
01-28-2007, 07:54 PM
Hi,
I purchased the rear LS1 conversion brackets from BRP and I am having some trouble finding out what parts I need for the swap -
I have a 1969 Camaro with staggered shocks. I have heard that you need two left setups for it to work.
I have been searching for days and I have not been able to find an exact list of part numbers or anyone who has documented the steps it takes for the installation.
Also, does anyone know how long my new studs should be for the new brakes to work?
Chris
01-28-2007, 10:15 PM
Yes, you need 2 lefts to work with stag's.
Wheel studs, I recommend metric type, Dorman #610-323 or Napa 641-1581
72SSAbody
01-29-2007, 09:26 AM
Chris,
Take a look at my old website: www.geocities.com/diels12000 (http://www.geocities.com/diels12000)
I've got the part numbers there.
Joe
aany001
01-30-2007, 09:04 PM
do you still need 2 lefts if your car is mini tubbed???
01-30-2007, 11:37 PM
depends on shock location. you can redrill the plates to rotate them up out of the way if you really needed to. heres another alternative...
Old Joe? does this mean you are making a new one??
Taylor1969
01-31-2007, 09:12 AM
Thanks for all of the information.
BRP Sells a relocation kit that puts both shocks in from of the axle. Does anyone have an opinion on that kit?
I think the cost is right at $150
Hammered
01-31-2007, 06:19 PM
What do you do for parking brake cables if you keep the original pedal and intermediate cable setup?
Taylor1969
01-31-2007, 07:27 PM
I am pretty sure that the ls1 cables work if you run the L&R calipers and brackets.
72SSAbody
01-31-2007, 09:05 PM
Nope, you can't out engineer The General. They've already performed the homework and I just want to pass along the part numbers. Unlike some companies out there :rolleyes:
Joe
01-31-2007, 11:25 PM
Hey Taylor,
yes those would work perfectly,
Hammered, you can use the stock LS1 rear cables and brackets, you just have to modify the frame brackets to relocate them closer to the front.
No, your web site Joe....LOL silly are you doing a new web site?
Hammered
02-01-2007, 05:00 PM
I have a '67 so I can run a L & R and have the cables pull from the front. The bottom of my car is already detailed so cutting and welding is a very last resort. I wonder if I can get Inline Tube or someone to make a ******* cable to fit?
02-01-2007, 10:41 PM
F****** Lokar dude. They can set you up. Just make bolt on brackets to secure the cables.
MarkM66
02-02-2007, 05:37 AM
Why metric?
MarkM66
02-02-2007, 05:45 AM
Would someone please post a link to BRP? Thanks
Taylor1969
02-02-2007, 06:34 AM
Why metric?
Metric is actually perfect in my case - I have ATS spindles and they have metric studs.
Taylor1969
02-02-2007, 06:35 AM
http://www.brphotrods.com
Phil (the owner) I actually a really nice guy. I am not sure why BRP doesn't get more discussion on here.
barno68
02-08-2007, 06:39 AM
You probably already got the part number for the left hand brackets, but just in case: 10444626
As for metric wheel studs... I could not find the knurl I wanted in 12mm for the fronts, so went with 1/2-20s instead. But the rears require no drilling to tap out for using 1/2-20 screw in studs. Just another option.
Brent
72SSAbody
02-08-2007, 05:33 PM
:hand:
Yep, www.engineeredvelocity.com (http://www.engineeredvelocity.com)
Remember I asked you if I could use some of your pics!
Joe
02-08-2007, 10:24 PM
cool, yes i did. Sweet stuff and great prices but one suggestion? Can you change the color of the prices?
My eyes almost poped out of my head... and not just because of the great prices. vin
Taylor1969
02-09-2007, 06:17 AM
Thanks for the replies everyone. I think that I'll be doing the BRP shock relocation and regular L&R setup and adding some new longer studs to my axles. BRP will weld the parking break cable bracket to the lower shock mount and the setup is supposed to work really well.
I plan on taking pictures of the whole process because this stuff doesn't seem to be very well documented anywhere.
72SSAbody
02-09-2007, 09:11 AM
I'll do that tonight Vince. I've also got another banner I've been working on. I'll put that up as well.
Joe
Widetracker
02-09-2007, 09:13 AM
What was the price of the rear ls1 conversion brackets from BRP for a '69 f-body? One thing I hate about their site is they have no prices.
dhutton
02-09-2007, 03:52 PM
I got this from BRP. Hopefully it is OK to paste it here.
> We also just finished a Brake kit that adapts the 4 Gen Camaro/Firebird disc
> brakes to your car also. The rear brake bracket/spacers are 39.00 and work
> with any 10 or 12 bolt rear end. The front kit is 249.00 and includes new hubs with new
> bearing,races and seals (exchange), caliper brackets and bolts, if no core hubs are
> returned a core charge of (40.00 extra). So you can go to a yard and buy the brake from a 98-02
> camaro/firebird and have 4 wheel 12"disc. Alum. Calipers on your car for less than 500.00
> bucks with my kit. Now that is a deal & your stock brake lines will work
> fine with the 98-02 calipers. Plus, do not forget to get the e-brake cables
> when you buy the rear brake set-up at the yard. We also have re-build complete kits Calipers
> and Rotors if you can't find any at a yard. We also make a In-board Shock relocations kit 149.00
> that moves the shocks in and give you room for a 275 Tire and the shock
> plates that bolt to the bottom of your springs have a bracket welded on to
> hold the new 4 gen E-Brake cable .These added Option make for a really nice set-up
