Results 1 to 11 of 11
01-24-2007 #1
- Join Date
- Nov 2006
- Posts
- 5
Caliper Brackets for a Dodge 8 3/4 rear end
Does anyone know of a source for caliper brackets for a Dodge 8 3/4 rear end? When I bought my 67 Camaro it had this rear under it. It's got posi and a 3.42 gear so I left it. I had moser redrill the axles for Chevy bolt pattern. I pieced together rear disc brakes using bolt on circle track Afco caliper brackets for GM metric calipers, 79-81 Tran-Am rotors, and 85 Seville Calipers. I getting ready to plumb the brakes and I don't have alot of confidence in the Afco caliper brakets. They are for a 3" axle tube. The Dodge rear is 3" but gets bigger at the flange, so I had to modify the brackets to work.
Thanks for any info.
76 Nova
67 Camaro SS-350 (cloned)
80 Z28
http://www.cardomain.com/ride/2535549
http://www.cardomain.com/memberpage/782333
01-24-2007 #2Master power brakes makes a rear disc swap kit for the 8 3/4" rear end. As far as brackets gop, try AR engineering, they have done some cool stuff with the Viper caliper's on the fronts and rears of Mopars. He may have what you need.
01-25-2007 #3
- Join Date
- Nov 2006
- Posts
- 5
Thanks for the tip! Doesn't look like AR sells any brackets for what I need.
Anyone else?76 Nova
80 Z28
02-11-2007 #4hi
these are the ones i use
very simple and clean
http://www.scarebird.com/4436.html
jason1974 charger se modified, 440 727 3:23's, twin turbo t61's,intercooled,custom mpfi,55lb inj, ms1 v3- 2.36,msd6a,msd coil,big rims(20's/22's,4 disk brakes,smoothed, slammed, and scary fast
http://members.shaw.ca/viper11/
02-20-2007 #5You can adapt ford cobra 11.7" discs on to that rear no problem. PM me with details.
Peter Bergman
71 Dart GT, Stroker SB, Built For The Turns!
03-01-2007 #6Tell me about this cobra conversion...I may try this.
03-01-2007 #7
- Join Date
- Dec 2006
- Location
- Los Angeles
- Posts
- 334
Try Scarebird...he's always on the Pontiac (PY) boards and is very helpful.
03-02-2007 #8I looked at his website and it really doesn't tell me squat for the rear disc. It pretty much states that he has the brackets, that's it. I e-mailed him so I'll see what I get for a response.
03-08-2007 #9
- Join Date
- Nov 2006
- Posts
- 5
If you get a response, let us know. I'd like to know what caliper and rotor fits that bracket.
Originally Posted by Bigblue73
76 Nova
80 Z28
03-09-2007 #10Here is what the scarebird retro-fit uses. PM me with you e-mail address and I'll send you the instruction. They look to be very well thought out.
1982-87 Lincoln Continental rear rotors
1979-85 Cadillac Eldo rear calipers
Flex hoses – 1979-90 Caprice,
Banjo Bolts – 1979-90 Caprice
03-10-2007 #11hi
my kit uses the 01 intrepid 11 7/16" front rotors, 81 transam or elderado rear calipers and i think the caprice hoses?
its a very nice kit, easy to install and easy to find all the parts at napa etc
