View Full Version : Caliper Brackets for a Dodge 8 3/4 rear end
zoom_ss
01-24-2007, 08:05 AM
Does anyone know of a source for caliper brackets for a Dodge 8 3/4 rear end? When I bought my 67 Camaro it had this rear under it. It's got posi and a 3.42 gear so I left it. I had moser redrill the axles for Chevy bolt pattern. I pieced together rear disc brakes using bolt on circle track Afco caliper brackets for GM metric calipers, 79-81 Tran-Am rotors, and 85 Seville Calipers. I getting ready to plumb the brakes and I don't have alot of confidence in the Afco caliper brakets. They are for a 3" axle tube. The Dodge rear is 3" but gets bigger at the flange, so I had to modify the brackets to work.
Thanks for any info.
Bigblue73
01-24-2007, 09:56 AM
Master power brakes makes a rear disc swap kit for the 8 3/4" rear end. As far as brackets gop, try AR engineering, they have done some cool stuff with the Viper caliper's on the fronts and rears of Mopars. He may have what you need.
zoom_ss
01-25-2007, 10:19 AM
Thanks for the tip! Doesn't look like AR sells any brackets for what I need.
Anyone else?
viper11
02-11-2007, 07:43 AM
hi
these are the ones i use
very simple and clean
http://www.scarebird.com/4436.html
jason
GMachineDartGT
02-20-2007, 12:38 PM
You can adapt ford cobra 11.7" discs on to that rear no problem. PM me with details.
Bigblue73
03-01-2007, 07:33 PM
Tell me about this cobra conversion...I may try this.
Karch
03-01-2007, 11:30 PM
Try Scarebird...he's always on the Pontiac (PY) boards and is very helpful.
Bigblue73
03-02-2007, 07:34 AM
I looked at his website and it really doesn't tell me squat for the rear disc. It pretty much states that he has the brackets, that's it. I e-mailed him so I'll see what I get for a response.
zoom_ss
03-08-2007, 09:07 PM
If you get a response, let us know. I'd like to know what caliper and rotor fits that bracket.
Bigblue73
03-09-2007, 09:22 AM
Here is what the scarebird retro-fit uses. PM me with you e-mail address and I'll send you the instruction. They look to be very well thought out.
1982-87 Lincoln Continental rear rotors
1979-85 Cadillac Eldo rear calipers
Flex hoses – 1979-90 Caprice,
Banjo Bolts – 1979-90 Caprice
viper11
03-10-2007, 08:16 AM
hi
my kit uses the 01 intrepid 11 7/16" front rotors, 81 transam or elderado rear calipers and i think the caprice hoses?
its a very nice kit, easy to install and easy to find all the parts at napa etc
jason
