View Full Version : Home made custom door panels. Help
LowBuckX
08-16-2004, 10:14 PM
I want to do custom Panels but need to know some sources for materials. Also what sort of board is used in the construction of the panel. Ive been told Water proof card board but I cant find a source.
Strand board I think its called. Any help would be greatly appretiated.
TonyL
08-16-2004, 10:21 PM
check this out roddoors (http://www.roddoors.com/streetrods.html) its all you need for the coolest stuff out there
nifty how to article (http://www.rodandcustommagazine.com/howto/74658/)
aside from that 1/8 inch masonite works great as a base. then stack layers of foam. a electric carving knife and D/A sander is your friend.
LowBuckX
08-16-2004, 10:44 PM
Thanks but I cant afford that price, anyother more cost friendly advice
TonyL
08-16-2004, 10:50 PM
basicly all those doorpanels are based on the masonite & foam idea, basicly you get some masonite (home depot.) some "extreme velcro" (also home depot) and high density foam (local fabric store) and some spray contact glue. make a cardboard template of the size door panel you need. transfer that to the masonite. spray with glue. coat with layers of foam, with shapes you design. to shape the foam, use an electric carving knife to get the general shape, then sand with a sander to fine tune.
when the final shape is done, spray with glue and press on the fabric of choice, working from the middle out, wrapping the sides by at least a 1/4 inch. if you want pulls or armrests, head to the junk yard and find some, paint to match.
use the extreme velcro to lock the panel on the door, or go all out and use factory clips. the door pull (armrest,) has screws that also will anchor the panel on.
Jim Nilsen
08-17-2004, 09:03 AM
I have found that the fiberglass bathroom panels will work the same as the masonite, and will eliminate the possibilities that the masonite will start to delaminate if moisture and humidity are high in its lifetime.
Don't get me wrong, the masonite does a fine job but I have torn out a lot of different materials over the years and masonite just doesn't hold up as well as the fiberglass or plastics will.
It all sounds good for everything else and goodluck.
Jim Nilsen
LowBuckX
08-18-2004, 09:38 PM
here is a good link for anyone else watching I like the whisper Faux leather but not sure on how soft it would be. http://shop.store.yahoo.com/yourautotrim-store/auto.html
gp001
08-19-2004, 09:02 PM
Below is a link to how I made very simple door panels for my Mustang. I used Keyston Bros (http://www.keystonbros.com/index2.html) to source all the materials. Keep in mind it was my first attempt ever at interior stuff and I wanted them to be very basic. Also, they sell "chip board" which can be used as a backing material.
http://www.2mfffabshop.com/drpnl.htm
Randy75
09-04-2004, 09:07 PM
Here is another site with alot of stuff to make door panels and interior.
http://www.selectproducts.com
