    Results 1 to 7 of 7
      Jun 2006
      NW burbs IL
      Baer Track and LS1 Master
      Ok, my eyes are killing me from searching on this topic.
      I have the Baer Track plus on my 69 Camaro ( 13" rotors C4 calipers w/ twin 38 mm pistons up front, rear single piston caliper specs ? ). I am considering using a LS1 power master cylinder ( 1.5" stroke 1" bore ) that I have.
      Has anyone done this, or know if it will work?
      I also need brake lines and would like to know if I can use 1/4" line for the entire system? Or does it have to be 3/16" front and rear lines with a 1/4" line going to the back?
      Can someone move this to brakes, I have no idea how I ended up in wheels and tires. Well I did mention my eyes are bloodshot.
      Matt
      Jun 2006
      NW burbs IL
      Made you look? I can see I'll be answering my own question down the road.
      Matt
      Nov 2004
      Colorado
      Quote Originally Posted by Bow Tie 67
      I used the LS1 (98-2002) F-body MC on my car with 13" c4 front and 12" LS1 rear calipers. It worked quite well.
      The C5 master is identical to the f-body but for the lines coming out the other side like a standard MC, and being 6mm line with 12mm tube nuts, one course one fine thread.
      Jun 2006
      NW burbs IL
      Thanks for the info, I would rather have the lines out toward the fender. Do you happen to know if the booster is the same between the f body and vette?
      Matt
      CHICAGO SUBURBS
      I know the firewall end is different. The master end should be the same. I gotta get by there to see your progress. It's has to be better that mine! FRANK
      Jun 2006
      NW burbs IL
      Thanks Frank, I realized the booster difference and see vette parts are fricken expensive. As far as progress, I have put quit a few hours in the project, but its still at a point where it looks like a bigger mess than a month ago. ' deep breath ' the good thing is I can still see the light at the end of the tunnel. Feel free to stop by anytime, I'm on afternoon shift this week and then days for three weeks.
      Matt
      Nov 2004
      Colorado
      I got a vette booster and master off ebay for $100
      The booster itself is the same but the mounting is different, and neither is a direct bolt up to the first gen.
