    Results 1 to 9 of 9
    Thread: C6 ZO6 Brakes
      Long Isand,N.Y.
      C6 ZO6 Brakes
      I just received my new C6 ZO6 brake set up for my 65 chevelle. My question is, Do i need a new master? I converted to disc brakes about 10 years ago. Using the stock setup from a 70 chevelle. I bought ATS spindles and the rear caliper brackets. Is there anything else i should know for this conversion? THANKS.
      Aug 2006
      What master are you now running ?
      1970 chevelle - awaiting heart transplant
      Long Isand,N.Y.
      I'm using the stock master from a 7o chevelle. I've heard that I should use an 1-1/8 bore size.
      curious what size rotors are the Z06 brakes?
      14" front 13" rear.
      Lead.
      LEADFOOT1
      1969 Camaro Pro-Touring project SOLD!!!
      NOW; as of 08-2006. Still a 1969 Camaro, BUT now a Convertible!, A 63 000 miles, 1 owner, 1 repaint in '78 that was stored inside from 1982 'till i got it car, and is now; Full custom tubbed to fit 19x8.5 and 20x13" Forgeline ZX3p wheels, w/345'-25-20's rear, C6-Z-06 brakes.
      AirBAr suspended +++
      1998 Dualie Crew Cab 3500/454 Fully Loaded.
      Jun 2006
      Long Island
      C6 Z06
      Hey Frank is that you?
      Long Isand,N.Y.
      Yeah, it's me. Dave is that you?
      Jun 2006
      Long Island
      Z06
      Hey whats up? I talked to Pete yesterday and he mentioned that you had got your brakes, very cool. I'm waiting for my set to come in, after we went to the beach I started ordering parts (my credit card is on fire). I needed to get the itch again and that did it. email me some photo's of the suspension when you finish, also let me know which master you go with. I am going to pick up a 1 1/8 from a C3 I think. Later, Dave.
      I have the same set up (C6Z) And am looking at the same problem. I got a few anwsers i will post for you to consider if you'd like;
      I'm also considering the use of a hydroboost unit. I spoke with Paul at Hydratech an he suggests some things too.
      I will edit, as pasting a few links demands i search thru my saved stuff.
      https://www.pro-touring.com/forum/sh...+cyl+bore+size
      http://www.popularhotrodding.com/tec...aking_systems/
      Oh and Dave, why C3? At that point why not the original C6 Z unit? I'm waiting on the specs of that unit (C6) from Fred Beans Chevrolet, where i bought the Z06 kit .(AT A GIVEAWAY price at that). So if your interested, i could share the info once i receive it. I wanted to spec out the original unit so i could at least get same in my own set up. I want to use the new Wilwood tandem unit and have a bran new '06 Duramax Hydroboost unit. The HB unit according to Paul will require some fabbing so i have to look into this.
      Lead.
      LEADFOOT1
