View Full Version : th350 park position
TheRoaringEagle
01-02-2007, 02:35 PM
i think my shift bracket position on my th350 is in park but i'm not very sure. it's pushed forward all the way?
paul67
01-02-2007, 02:42 PM
Is the gearbox shift arm aiming up or down
Project69
01-03-2007, 07:08 PM
one way to findout is push the car, if you hear a ping and the car wont move forward, then its in
TheRoaringEagle
01-04-2007, 11:28 AM
the tranny right now is out of the car but the shift arm is pointing at an upwards angle.
6'9"Witha69
01-04-2007, 11:52 AM
the tranny right now is out of the car but the shift arm is pointing at an upwards angle.to the front or back?
matthimself456
01-04-2007, 01:29 PM
Dont know the answer but I think this would be easier if we used clockwise and counterclockwise terms instead of forward or backward due to different shifter arms.
6'9"Witha69
01-04-2007, 01:56 PM
Dont know the answer but I think this would be easier if we used clockwise and counterclockwise terms instead of forward or backward due to different shifter arms.Good idea.
Park is farthest clockwise when viewed from the driver's side of the trans.
TheRoaringEagle
01-04-2007, 07:33 PM
awesome, hehe. also i was wondering if there is an alternate solution to the bellhousing bolts on my th350. i am using repro stock bolts and the factory assembly manual says to wrench it at 25-30 lbs. ft. and i noticed the bolts taper in in the middle. it just seems very weak to me (i actually already over torqued one and broke it but luckily i could still unscrew the whole bolt out)...
i saw some ARP bolt kits, and wondered how much more force i can use on them. Or what is recommended, what heavy duty cars have, or just some words of reassurance that these stock bolts will hold up and i am just paranoid.
