    Results 1 to 13 of 13
      Jun 2006
      Katy,TX
      Second gen F body 1LE/PBR kit?
      OK guys I have 12" 1LE rotors and 12" B body spindles, is there a caliper bracket/kit to use a PBR type caliper with these other than an entire Baer kit? I know Baer has a 12" kit but I'd bet the bracket by itself isn't aaliable or way too expensive for just a bracket.
      I tried a "search" and came up empty.
      May 2002
      Northern California
      I've only seen brackets for a 13" rotor for sale separately. Give the guys at KORE a call.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Chico, California Nor-Cal
      Try using Wilwoods GMiii alumonim caliper, they make a direct replacement that is 10 lbs lighter a side than the stock one, and stronger than the small PBR claiper on the 1le, they are $99ea new
      Keith
      Dublin, CA
      I made my brackets, but they were for the LS1 setup with stock spindles. If you have the B body spindles, why can't you use their caliper brackets?
      Jun 2006
      Katy,TX
      B body spindles take the same caplier as the second gen. unless the newer B bodies(Impala SS) use a PBR type caliper and still swap on in place of F body spindles.
      Jan 2007
      A house
      try www.performanceonline.com they have a custom 2" drop spindle just for that type caliper..
      Aug 2005
      Hamilton, NJ
      Scott from NJ.
      Vent Windows Forever! ...
      Jun 2006
      Katy,TX
      OK guys what's the difference between LS1 and C5 calipers/rotors? The KORE site says the C5 calipers have 40mm pistons vs 43mm for the LS1(smaller?) and that the C5 rotor is 1.25 thick roughly. Is the LS1 around 1" like the 1LE from the third gens? Maybe C4 stuff?
      Still trying to figure this swap.
      Pittsburgh, PA
      I cant confirm the bore sizes but the LS1/C5 rotors are the same thickness. 12" for the f-body, 13" for the Vette.
      I actually did my own brake arrangement. I used a C4 rear 12"x.81" kit from Touring Classics & Used the b-body/1LE 12"x1" front rotor & Stainless Steel brakes aluminum dual piston calipers. They fit in the same spot as the D52 caliper, uses d52 pads, and are available with bores for manual or power apps.
      Its not a the last set of brakes it will have but they do all right for now on the street.
      Shane
      May 2002
      Northern California
      Quote Originally Posted by Skip Fix
      difference is rotor back space. Aren't you using b spindles? Sell them 12" rotors and get a set of C5's. Check with Joe, he should have a set of brackets for you. http://www.geocities.com/diels12000/BrakesII.html
      Jun 2006
      Katy,TX
      Trying to keep the 12" but a PBR type caliper so IF I ever want to throw on the 15" snowflakes I could.
      Oct 2006
      Norway
      Will camaro-98 calipers bee a good choise for us that have done the 1LE upgrade ?
      Jun 2006
      Katy,TX
      I've got a line on some 04 GTO calipers I might have to figure a swap.
