    Results 1 to 10 of 10
      Aug 2006
      Caliper bracket mounting bolts. Only OEM should be trusted ?
      I need to buy the bolts that hold the Corvette caliper brackets against my ATS spindles. I thought that theyr were the same as the 4th gen f body but turned out to be different when I finaly got started on the assembly.
      Can I go with matching grade 8 bolts for these or do you guyz think OEM bolts are a must for this application?
      1970 chevelle - awaiting heart transplant
      Red Deer, Alberta, Canada
      I'm running gr 8's.
      -Matt
      Matt
      Instagram: Cst_koon
      Aug 2006
      Quote Originally Posted by protour_chevelle
      I'm running gr 8's.
      -Matt
      Same setup as me ?
      Aug 2006
      Bought some grad 8's
      Quote Originally Posted by jfman
      Same setup as me ?
      No but I doubt it matters Just run gr8's and youll be fine.
      -Matt
      Matt
      Instagram: Cst_koon
      Aug 2006
      Yeah I called gm and they said $6.84/bolt and 1 week. Local hardware store was $4.59 for all 4.
      Central Texas
      I purchased GM bolts and washers for my ATS spindles. The bolts are only threaded on the end and it also calls for a washer that is very thick. After seeing it I am glad I waited to get it from the dealer....
      GM Bolt # 14084051
      GM Washer 10268875
      Aug 2006
      Quote Originally Posted by KMD
      GM Bolt # 14084051
      GM Washer 10268875
      What size wrench do you use with these bolts ? How much was it for everything ?
      Sep 2001
      Accord, NY
      When I did my C4/13" conversion I needed different length bolts and went to the hardware store for grade 8.
      69 Camaro convertible, 410, M22, 8-pt cage therapy program. SOLD.
      68 camaro - SOLD
      67 Bel Air - New street project with perfect floors, frame and trunk!
      Central Texas
      jfman,
      I believe I used a 13/16 socket. The 4 bolts and washers came to $26.52 from the dealer.
