Results 1 to 9 of 9
11-22-2004 #1
- Join Date
- Aug 2004
- Location
- Maine
- Posts
- 594
65-66 mustang suspension potential?
Hey all, got a quick question for those who are familiar with the old Mustang suspensions.
I'm one of those people who likes to plan things waaaay ahead of time... so I'm thinking about what the next project car will be (probably in 2 years, when I'll be out of grad school and have a little extra cash) and I'm really leaning towards the 65-66 mustang fastback. (no, not going to get rid of the Camaro... want a second project.
So, for you suspension gurus, how does the suspension in factory form stand up design-wise? The front suspension is a little different than my '68 Camaro and looks somewhat similar to the front suspension in my 1990 Nissan 300ZXTT. Out back are leaf springs and inboard shocks at quite an angle.
Is the suspension setup a good one? Are upgrades like the Global West systems a big improvement over factory? Or, should I be considering chopping out the old suspension completely and putting in a different setup all together? How about reinforcing the upper spring/shock tower up front... I hear this is a weak spot?
This isn't going to be a flat out racer... just a fun around-town drive. But I'm a perfectionist and I would rather do it once and do it right than do a second rate job and always wish I had done something else.
Thanks for any and all comments.John
11-24-2004 #2suspension
Classic mustang suspensions can be set up to perform with either new or old technology. Shelby did it with his original GT350's. There are also some great new technologies that are bolt on (Global West and Total Control Products both have great suspension set ups for classic mustangs)
I will dig into my files and post some links for you.William Rouleau
Project PonySnake - '67 Mustang Fastback
11-24-2004 #3The cars need a lot of work to function properly - the chassis flex a ton.
There are 3 companies you should look at
www.globalwest.net
www.totalcontrolproducts.com
www.maierracing.com
They are doing the absolute best early mustang suspension stuff around right now1971 Camaro, 383 stroker ~500HP,M21 Trans with lightened flywheel. All Sorts of Auto-x Goodness in the Suspension. 12" Brakes ->SOLD
But ask me about my 2004 STi Auto-x car...
Just call me Brett
11-26-2004 #4
- Join Date
- Aug 2004
- Location
- Maine
- Posts
- 594
Thanks for the info guys.
I'm looking at the link to Total Control Products and they have a pretty trick looking rear suspension setup... but the coil overs are almost parallel to the ground?? How can this spring the suspension effectively? Seems very strange. Check it out at http://www.totalcontrolproducts.com/rearcoil.html
I've been kind of toying with the idea of building a full-framed car out of one of these... basically just welding connectors bridging the front subframe to some boxed steel rear frame rails and then having some caged-nuts to bolt the body to that. Any thoughts?
Thanks again for the links. Any and all comments are appreciated.John
11-26-2004 #5
