    Results 1 to 20 of 26
      Jul 2003
      Anaheim Hills, CA
      Damn tire dilema
      Ack!
      I have an ENTIRE week to finish the exterior of my Fairlane.. paint the hood, add spoilers, paint rear panel, install tires/whees, replace vinyl top, etc..
      We are shooting it for a cover on the 8th.. lol.. what am I.. Overhaulin?
      Anyways, trying to find tires and I just can't find what I want..
      Running 17x8 front and 17x9 rear rims. I wanted a taller sidewall but everything is a 40 series for the rear. The one Nitto tire I found with a 50 series rear, but it doesn't have the right size for the front. Would it be wrong to have non-matching tread patterns? I'm thinking yes..
      Want:
      245/45/17 front
      275/50/17 rear
      Could go as high as a 255 front and 285 rear and the sidewall has some flex as well, but I can't find anything. Oh, and it would be better to find Nitto or maybe Toyo tires since they advertise.
      I should have gotten 18's but I was trying to "keep it real" and not make the 15-inch wheel crowd crazy.. lol.. plus Vintage Wheel works doesn't make these V60s in an 18-inch wheel.
      Why can't companies just make what we need..
      1968 Track Rat Camaro:
      Beaufort , NC
      Hell Tire rack did not even show a 275 50 17!! But the do have Dunlop SP Sport 5000 Symmetrical in 275 55 17..
      1992 Lexus SC400 daily SOLD
      1966 Porsche 912 Outlaw SOLD
      1968 Ford F-100 sb SOLD
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by Restomod
      The the Nitto NT450 has the perfect rear tire..
      255/50R17 27.03
      275/50R17 27.88
      The rear tire is perfect at 27.88 tall... the front it too tall at 27.03 and would run the fender well. If the 255 came in a 245 or a 40/45 series all would be good.. lol
      Mainly I'm just whining... lol
      Will most likely run a 275/4017 and 245/45/17 tire.. it's a low profile world we live in..
      Lafayette
      Why not run a 235/45/17?
      Is it really a bad thing to non-matching tread patterns?
      Im running 235/45s KDW's and 285/40s KDWS's.
      Scott
      Built LTX, TKO600, 12Bolt
      SouthTX
      Quote Originally Posted by lower90xcab
      I would believe most people would think it's a bad idea, including myself. That is, unless you have drag radials on the rear, then that's cool
      im running those 50's series nittos... i love the look.
      Los Angeles
      if you run drag radials in the rear, people usualy give you slack. get these :P Weld Evo Axis 5
      -Tas
      '04 Mustang Saleen sc281 speedster
      '67 Mustang notchback: The fabled $500 non running project car: 308, auto, 2 barrel (now 4), AC(now removed), 5 lug, disk front, drum rear, power brakes and steering... that I got started and home for $65 :D
      Sarasota, Fl
      Hey Steve, if you wanna "keep it real", consider using OE sized tires, like the 235/55/17s that are used on new Mustangs. Talk about a nice bit of sidewall...
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by RobM
      Yea, too bad the fronts are so tall.. at 27-inches I doubt they will work...
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by THX 138
      The back is the problem.. even drag radials are 40 series..
      Oh, picked up the wheels yesterday.. Vintage Wheel Works V60s..
      Feb 2003
      Houston, TX
      Hell, go with the "Donk" style and put some 30" wheels/tires on it. Call it Project FairDonk
      Co-Founder, LS1TECH.com
      www.DV8Motoring.com
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by Nine Ball
      thanks for the great idea..
      lol
      San Diego, CA
      Someone correct me if I am wrong, but why would it matter to run two seperate tread patterns between front and year?
      Pirelli PZero Assimetrico's and Direzionale have completley different tread patterns, one set is specifically designed to be a rear tire, one a front.
      I think you could get away with it... You just dont want to do your rotations funky.
      http://www.tirerack.com/tires/tires....l=PZero+System
      yeah im running them in the back.. the fronts are smaller. they look killer in the back of the car though. plus alittle more side wall helps achieve more slip angle
      Oct 2005
      Orlando, Fl
      I would try to get close to 26" in the front. 27" seems pretty tall.
      Michael Barnes
      71 Chevelle - LS1/T56 swap - On the Street!!
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by stealth71
      Yea, that's the problem.. all the 27-inch tall front tires don't have a lower profile size in the same tread pattern.
      I got the factory to rush me a black vinyl top.. Instead of two weeks I can pick it up Monday afternoon
      I will sand the hood at Best of Show on Monday and prep it for some satin paint.
      lowering the car will most likely involve a cutting torch.. or I could just heat the spings to red hot and jump on the front bumper..
      Jul 2003
      Anaheim Hills, CA
      Quote Originally Posted by aonghus
      Purely asthetic reasons.. just sorta looks funny.
      I have different tires on the front and back of my car for now because they were temporary. The tread pattern was not the problem, it was the two different compounds that bothered me at the track. On the street it drove fine.
      I also want a wider tire that is 27" tall. The widest tire I can find is a 255/50/ZR17 I can fit a 335 but I can not find them in a 50 series.
      Randy
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      Ridgecrest, CA
      1968 Plymouth Road Runner
      Jun 2002
      Long Island, NY
      Quote Originally Posted by ProBell
      Randy
      335/50/17 would be over 30" tall. You'd want a 335/40/17 (27.5" tall).
