    Results 1 to 20 of 27
      Granger , IN
      I NEED HELP - BAD ! Brake troubles on 99 Silverado
      I have a late 99 Silverado 1/2 ton ext cab with a 5.3 .
      we put new ROTORS and PADS on all 4 corners - No big deal right ?
      WRONG.
      Heres the problem and i cant figure it out.
      Front brakes work fine.
      REAR BRAKES - Both side are continually applying pressure and causing the Rotors to get EXTREAMLY HOT .
      ( Naturally , as they get hotter the pressure is greater and it will slow the truck down by itself )
      I've only made test runs !
      Everything was fine befor , just worn and time for maintenence.
      We didnt release any lines , just droppen in pads and slid on new rotors.
      Greased all the slider pins too.
      WE JUST REPLACED THE CENTER REAR BRAKE HOSE from the frame to the rear diff ( thought maybe a colappsed hose) but SAME THING.
      ANYONE GOT A CLUE THAT WOULD HELP ME OUT !
      I'll put you on my Christmas Card list if you can help me figure it out ...LOL
      The Voices in my head tell me i need more cars
      Granger , IN
      Anybody !
      Nov 2001
      Sacramento Ca
      Sounds like the wheel cylinder is dragging. you may need to lube them. happened to me.
      Tony Langlois
      1966 Corvair Monza
      Granger , IN
      I dont think it has wheel cylinders ... Its DISC !
      BTW , IT IS NOT A PROBLEM WITH THE EMERGENCY BRAKE SET UP , Its the main Braking system dealing with the Pads & Rotor.
      i dont think it the calipers either because they compressed ok , and you can see them compressing & decompressing when we test them.
      Besides , i wouldnt think that BOTH sides would go bad at the same time .
      THANKS FOR TRYING THOUGH
      Im still confused .
      ANYONE have knowledge of the ABS system ?
      Delaware, OH
      Try pulling the ABS fuse and see if it repeats. It's going to throw a trouble code when you do, BTW.
      Nov 2000
      O-town
      The rear calipers have phonalic pistons and when you pushed them back in they now are sticking, the pistons are not true anymore, round, try that,
      friend had a 99 Blazer had the same problem, we screwed around with it, took the piston in and out, ended up with new rear calipers, worked great, just reuse the copper crush washers because the others are junk!
      Let us know what happens.
      Nov 2000
      O-town
      I read that the pistons are moving in and out, but are they moving back in enough?,
      did you put a clamp on the lines and break the bleeder screw loose when pushing the pistons back in??
      if you don't, you can back flush the ABS unit with trash, very common with GM trucks,
      Nov 2001
      Sacramento Ca
      piston is what i meant to say. Usually when they crush them back in they use C-clamps. this can bend them and make them less than round. or worse, the cylinder that the piston rides in can be come gouged. Or the piston itself can become cocked or cracked. This causes dragging, and will cause the pads to not let off enough to give you freewheel.
      Tony Langlois
      1966 Corvair Monza
      Granger , IN
      Thanks for the info ... I have a GM tech aquaintence comming over with a scanner to check...
      No , we didnt open the bleeder when we pushed the piston back in .
      We did use a C-Clamp ...
      I dont think its the piston / calipers but i undersatnd the thought behind that...
      Only because its BOTH side on the rear ...
      We did the same thing on the fronts with no problem...
      Yes , the calipers are moving in & out , ENOUGH , i dont know...
      If i go for a test drive around the block , by the time i get back , THE REAR BRAKES ARE EXTREAMLY HOT !
      If i hit the Bleeder screw , it releases pressure and the brake are ok , TILL I HIT THE PEDAL.
      I am leanning twards the ABS system and for some reason it is NOT releasing the pressure...
      THANKS FOR THE HELP , I'll try a few more things!
      Aug 2005
      Hamilton, NJ
      I with the bad piston theory, but it is very important to break the bleeders open when pushing pistons in. I would not be surprised if that damaged something.
      Scott from NJ.
      Vent Windows Forever! ...
      Nov 2000
      O-town
      Your giving me all the signs of the Phonalic pistons out of round, The Blazer did the same thing!!!!!!
      ABS I think you'd get a SRS or what ever light,
      Tomball, TX
      I may be way off base here, but could it be something with the F/R brake bias? I know nothing about newer GM trucks, but could it have gotten adjusted somehow when you were doing the work?
      Edit: Ehhh, now that I think about it, I guess that wouldn't explain why the calipers are still applying pressure to the rotors when the brake pedal is released. I guess I defeated my own theory
      Ryan
      '68 Camaro (slowly coming back together...very slowly)
      Central CA USA
      Did you remove the master cyl cover to release any possible pressure?
      Granger , IN
      Yep , we did remove the master cyl cover , and it has maximum fill line .
      The fluid was higher than that so i removed some till it was at the line.
      Guy came by with the scanner and ran a diagnostics check --- NO CODES SHOWED UP.
      he went ahead and bled the ABS system ( i dont understand that because you dont have to bleed anything like you would think - its done internally with thie scanner)
      STILL DOING THE SAME THING...
      He checked the rear calipers and YES, they move in & out ...
      Going to replace them anyways ( there goes another 100+ )
      thinking that they may be "OUT OF ROUND "
      or that since they were out so far the there may be debris ( rust , dirt , what ever ) in the piston cyl thats just enough to allow it to be compressed with a clamp but not with line pressure.
      THANKS FOR ALL THE HELP AND IDEAS TO TRY ...i'll let you know.
      Nov 2000
      O-town
      That's exactly what I'm trying to tell you, the pistons were out to far, the phonalic is now out of round and it's hanging up in the body,
      Granger , IN
      I know , thats why i put it in parenthasise ..i was giving you credit ..LOL
      It was a last resort , because it seemed as though the calipers were working and they did collapse ok when we installed the new pads.
      the other contributing factor was that with the aluminum calipers ( rather than the cast they used to use , onece they are out so far the build up corrosion and causes the same thing...
      BUT AFTER REPLACING THE CALIPERS - I NOW HAVE PERFECT BRAKES!
      Thanks for the help!
      ANOTHER CRISIS OVERCOME!
      Nov 2000
      O-town
      I was being addiment about the calipers, because this was the exact problem we had and after 3 hours of screwing with them and talking to my friend who owns a shop, new calipers fixed it and home they drove,
      Glad I could help,
      Garwin, Iowa
      I've seen alot of problems with this design calipers sticking after pushing back in for a brake job. As far as not opening the bleeder to push the pistons back causing ABS problems, I have not seen it in 14 years as a master tech. I agree that is the "CORRECT" way to do it, and yes you could push crud back to the ABS motors. But in reality, not opening the bleeder would rarely if ever cause a problem like you were having. Strategy Based Diagnostics- always start with the basics. Glad to hear you got your problem solved.
      DUBUQUE IA
      check the rotors you may have the wrong rotors. 99 was the change over year and there are two different rotors. i have ran into this problem. just never left the shop
      barry
      Nov 2000
      O-town
      Hello!!!!!
      Did you read "after REPLACING the caliper" he's got great brakes!!!!!
      Hello!!!!
      WTF?? did you read any of this post??????
