View Full Version : Fancy new wastegates! ! !
ProStreet R/T
11-30-2006, 03:04 AM
We have been using the Tial 44's for a while (that actually flow better than the 46) but even with a pair of them it's been a bit of a flow restriction. Causing the boost to fluctuate on the top end and making it a bear to tune. Even with a 95% ideal WG location on the outside radius of a bend right before the turbo. Well lets just say with these monsters it's not going to be an issue any longer.
From left to right:
60mm :evil:, 50mm, and Tial 44mm
LOOK AT THE SIZE OF THAT THING. 2 1/4" in/out ports with V-band clamps. Valve has 1" of travel, all stainless housing, and they claim it will last at least 1 million full cycles on a set of O-rings at over 40psi. I have no idea how many times a normal WG cycles, but I think that should be sufficient.
:hail::hail::hail::hail::hail:
Needless to say with a pair of 60's I don't think we will have any problem keeping the boost down with the "big" turbos. What can I say, we thrive on absolutely retarded overkill.
We'll be trying the 50's on a car running a pair of 76gts turbos to see how well everything works on a somewhat normal setup, something fairly tame in the 1000-1300rwhp range. :smoke:
Turbo Hen
11-30-2006, 05:31 AM
HMMM i currently use the Tial 44's with my pair of 70's & dont have any problem with boost creep at all. My wastegates even dump back into the downpipe.
What kind of position are your wastegates mounted in & how far away from the turbo inlet are they?
ProStreet R/T
11-30-2006, 08:11 AM
It's not a design issue at all. The path to the WG is short and very direct on the outside radius right before it goes into the turbine housing.
Here is a shot from a mockup piece but you get the idea. https://static1.pt-content.com/images/noimg.gif
510ci near 7k rpm motor making almost 1400rwhp on kill (maybe more, will know shortly) flows a ton of air.
Plus the big ones just look SOOOOOOOOOOO much cooler, and being able to clock the air ports is a niiiiiice feature.
jdpepper
11-30-2006, 09:53 AM
Who makes the bigger wastegates and where can I get them?
Turbo Hen
12-01-2006, 10:23 AM
Hey bro its Carm (Stroked-Z)
What you doin now lol! Still using the MP 70's or ?
shmoov69
12-01-2006, 04:31 PM
[quote=Turbo Hen]HMMM i currently use the Tial 44's with my pair of 70's & dont have any problem with boost creep at all. quote]
How much boost does the kitchen table let you get? LOL!
:poke:
ProStreet R/T
12-01-2006, 06:21 PM
www.jgstools.com Tell them the viper guy sent you and they should hook you up with a decent deal.
jdpepper
12-02-2006, 12:23 AM
Whats up Carm, I'm still rockin' the MP 70's to the tune of 8.7@157 plus there's more in it :woot: The bigger waste gates are for my new/old bullet
How long b4 your new car is done?
jdpepper
12-02-2006, 12:26 AM
www.jgstools.com (http://www.jgstools.com) Tell them the viper guy sent you and they should hook you up with a decent deal.
Thanks for the hook up man:cool: I'll call this Monday
Turbo Hen
12-02-2006, 11:41 AM
Trying to get her done for early spring.....as soon as i can finish the diff, then i can build the control arms for the front to position the rim where i want it & start dropping in the old powertrain/fuel system & ignition from the other car.
-Carm
