View Full Version : gas tank removal
crazyfireman
11-27-2006, 04:57 AM
Is it really as easy as it looks? just the two straps, and filler neck??
muthstryker
11-27-2006, 05:43 AM
some other wires too
crazyfireman
11-27-2006, 06:47 AM
Wires? what wires would be hooked up? i though it had a cable style gauge.
qwik1320
11-27-2006, 06:59 AM
Two wires are hooked up to the sending unit. The ground wire is usually screwed into the rear frame somewhere and you should be able to see and disconnect that before dropping the tank. The other wire runs to the rear wiring harness where you should be able to unplug it.
crazyfireman
11-27-2006, 07:02 AM
Cool, Thanks
