View Full Version : 1970 Challenger what width 17s?
68Formula
11-16-2006, 07:58 AM
Did a couple searches, but not much info. and it was a little old, so I'm hoping there is new data out there.
Stock suspension and body, what is the max front and rear tires, rim width, and what is the optimum backspacing?
Pics would also be good.
Thanks.
Bigblue73
11-16-2006, 09:08 AM
Im running 17 x 8 on the front with 245/45/17 and 17 x 9 on the rear with 275/40/17. Backspacing is straight up at 4.5 on the front and 5" on the rear. No rubbing issues at all.
Send me a PM with your e-mail address. I did a layout of a 17 x 10 with 5.25 backspacing and it looked like it would fit with a 285 or 295 tire.
Cheers!
68Formula
11-16-2006, 10:25 AM
Thanks! PM sent.
Rolling_Thunder
11-18-2006, 01:56 PM
generally on a mopar you want around 0 offset... so backspacing should be made accordingly
Windsma
07-10-2012, 12:33 PM
before i pull the $3000 trigger? (customer's money so i cant get it wrong)
bone stock stock 70 challenger dana60 front disc, rear drum.
17x8 4.5bs front w/ 245/45 17
18x8 4.5bs rear w/ 275/40 18 other option, if it will fit.. 18x9.5 5.5bs
will that work? will it look right?
ive looked all day for an answer :nopity:
thedodgeboys
07-10-2012, 07:10 PM
You will find the answer here sorry I didn't want to look it up for you :)
http://www.cuda-challenger.com/cc/index.php?topic=19470.msg835460#new
Windsma
07-11-2012, 05:45 AM
Thanks ive read that one a few times already.
I guess the customer will have to settle for a smaller tire.
sccacuda
07-11-2012, 08:45 AM
295 will fit with no issue. 315 if you nail the backspace perfect.
