View Full Version : Finding the angles
protour_chevelle
11-14-2006, 08:41 PM
Can someone find the angles that are circled. The drawing is not to spec.
-Matt
11-14-2006, 10:56 PM
they're right there in the circles?!?! LOL
All that geometry and no protractor??
11-14-2006, 11:16 PM
http://www.lawrencegoetz.com/protrac.htm
astroracer
11-15-2006, 05:25 AM
Can I ask why you are designing the rails with all of those compound angles? It would be much easier to build the kick-up flat and simply step over to it at the first joint. There is nothing to be gained for strength with the compound angles and it just makes it very difficult to build....
Mark
protour_chevelle
11-15-2006, 11:33 AM
I was going to use as many 90 degree ends as possible with the angles to get my set back and height.
Total width from end to end is 41" so I might have to change my lengths inbetween(but not the top 4.5" piece)
Mark, I was thinking about that. Your pretty much saying to build the kick up AND step back into the same piece... If thats the case... My 14" lengths will now be 17" which is fine. I was concerned with how to tie into the frame the easiest way. As it sits its a pain in the ass, but I should be able to get it. Could you then help me with those angles?
I figured that I would ask here first,.. and Vince, its not to scale, its just my ideas on paper. I'll hit the graph paper tonight if nothing else.
-Matt
protour_chevelle
11-15-2006, 11:59 AM
Definately have to go back to the drawing board. I have to clear a floor brace, come up 4.5"s to be flush with the floor pan, and another 4.5"s to be at the proper height.
-Matt
astroracer
11-15-2006, 12:28 PM
90 degree cuts won't work well when fitting tubing at compound angles... You will end up with a bunch of cliff hangers and open tube ends to weld too.
Give me a couple of days. Work up your "new" design and post it. I'll see what I can do with it.
Mark
protour_chevelle
11-15-2006, 12:34 PM
Mark
Not pickin up what your layin down Mark. lol the "Cliff Hangers and open tube ends to weld too) isn't making sense.
-Matt
Madspeed
11-15-2006, 08:58 PM
He means your gonna have ends hanging over other ends and d huge gaps to fill
you must split the angle evenly to get matching ends o butt together and weld
And just think I dont even have grammer school education =)
astroracer
11-16-2006, 05:21 AM
Okay Matt, I did a quick design study this morning using the dims you gave me in the PM...
TOP VIEW
https://static1.pt-content.com/images/pt/2006/11/mas0001_topview_0001vi-1.jpg
REAR VIEW
https://static1.pt-content.com/images/pt/2006/11/mas0001_backview_0001vi-1.jpg
SIDE VIEW
https://static1.pt-content.com/images/pt/2006/11/mas0001_leftsideview_0001vi-1.jpg
CLOSE UP OF OVERHANGS
https://static1.pt-content.com/images/pt/2006/11/mas0001_cliffhangers_0001vi-1.jpg
CLOSE UP OF UNDERCUTS
https://static1.pt-content.com/images/pt/2006/11/mas0001_openends_0001vi-1.jpg
You can see a lot of over hanging and undercut corners with this design. Of course it could be done by hand fitting small pieces into the undercuts and trimming the overhangs and fitting small pieces there. That is a lot of hand fitting but you could make it work.
Mark
protour_chevelle
11-16-2006, 11:42 AM
Wow, Thanks Mark!!! I'm gonna shoot you another PM.
-Matt
Midwest Performance
11-16-2006, 12:40 PM
Mark (astro) are you using Solid Edge or Solid Works for you pictures?
Thanks Kevin
astroracer
11-16-2006, 06:58 PM
Kevin, it's UG NX3 (here at work). I built the model in less then 5 minutes with three straight lines and a couple of trims.:twothumbs
Mark
