Results 1 to 5 of 5
Thread: Wheel offset
11-14-2006 #1
Wheel offset
Ok, question about wheel offset. I want to finally figure out what size rims I need for my car. BUT have an issue with calculating the backspacing. Backspacing is measured by laying a straight edge acrost the lip of the rim, and measuring to the hub mating surface. BUT the rim width is measured from inside the lip. To center my tire properly, won't I need to know the width of the rim lip? Would this not be needed if a wheel was listed with offset and I wanted to figure out the backspace too?
11-14-2006 #2
- Join Date
- Jun 2006
- Location
- Indianapolis,IN
- Posts
- 1,605
Back spacing and off set are two differant measurments but achive the same thing. Offset is a measurment from the center of the rim.So if you had a 8" rim and the offset was listed as 0mm it would be the same as 4.00 back spacing.Back spacing is a measurment from the mounting pad to the outer rim lip.What kind of car are you trying to figure rim sizes?
11-14-2006 #3
