Results 1 to 20 of 26
Thread: 4L80E & paddle shifting
11-12-2006 #1
my project is to put a 4L80E behind a pontiac 455 in a '61 bonneville. i seen a couple others are doing a similar combo, so i'll prob have other Q's coming at you soon.
in the meantime, i'm sourcing some other parts. in particular, i would like to go with headers instead of long branch manifolds, but i'm afraid the collector tubes are going to be in the way of the column shifting linkage. at least it would be on the TH400 i had.
then i got to thinking, with a TCI setup, is it possible to not have a column shifter at all, and control everything off the paddles or otherwise? generally, the TCI + 4L80E defaults into using the column lever, then hit a switch and it will accept input into the manual harness (from paddles).
any thoughts?
thanks, Scott.
