View Full Version : 60 Impala fitment ?
datsbad
11-09-2006, 07:54 PM
What will fit on this car with out any cutting?
I am assuming that 18x10s and 20x10s would be the ticket. any ideas of backspacing and tire size?
Chrisbequick
11-09-2006, 09:59 PM
TTT! I'm curious, too. I'm putting 20s on my '64 Impala and it seems like there's very little info on early B-bodies out there.
-Chris
PRRC
11-10-2006, 09:53 AM
Hey Guys I think I can help you out on the Impala Questions.59-64 Impalas use the same x frame.Wheel base on the 58-60 are a little differant than the 61-64. But as a hole preety much the same. On the rears you can run up to a 22.But most common is a 20x10 with 5.5 b/s if your running stock brakes and 5.75 b/s if your running aftermarket disc. set up.
20x8 or 20x8.5 use a 255/35/20 4.75b/s
20x10 use a 275/35/20
275/40/20
295/40/20
front I would not recommend a 18x10 it will rub on the inside frame rail.18x8 is common but I have seen a 20x8 run in the front or even a 19x8.b/s on the 18x8 would be 4.5 standard brakes or 5 with large disc.as far as tires go on the front most common is 245/40/18 or 235/40/18.I you need anymore help give us a call Im sure we can help you out.Hers a pic of the car were doing now.hope this helps Tim
