    Results 1 to 6 of 6
    Thread: DSE tub limit?
      Celina, Texas
      DSE tub limit?
      I see that DSE says their tubs will fit up to a 335, but is that just the tub or with the leaf spring? I'm wanting ot put an aftermarket clip in while using their deep tubs.
      What is the width from outside-of-stock-rail to outside-of-stock-rail?
      Jun 2002
      Long Island, NY
      You can only fit a 335 if you notch the frame rail. On a '67 / '68 335 is about the biggest you're going to get in the tub, with a fully notched rail. You should be able to fit a 345 on a '69. I can't recall exactly off of the top of my head, but I believe I had about 15 1/4" from the center of my notched frame rail to the un-rolled wheel lip on my '68. Even with aftermarket rails, the limit would be a 345 as the tubs are only 3" deeper. If you want anymore room, you'd have to fab up some wider tubs, or section and widen the DSE tubs.
      Celina, Texas
      Thanks for the info, Ralph.
      Leaf springs(even with offset hangers) will interfere with tire if you're looking to go with wider tubs than dse,needless to say a new back half frame will be needed.
      Jerry
      Camtender,Privateer by choice
      Member of Hot Rod Power Tour Long Haul Gang 03'
      Winner of the 2nd annual Pro-Touring.com Run Thru The Hills drag racing event sponsored by Musclerides.com 06'
      2nd in class @ Big Bend Open Road Race 07' http://www.youtube.com/watch?v=Nti3UarUwzU
      Record holder @ The Texas Mile 08' for 1st gen. camaros http://www.youtube.com/watch?v=lvEzlnnAB8I
      http://www.youtube.com/watch?v=6L0sYaMnni4
      Celina, Texas
      I guess I am wondering if I can back half, using the DSE tubs, if the leaf springs limit tires to 335, or is it the frame rails? Can I get more room with a 4-link and DSE tubs than with their tubs and offset leaves? What hits first?
      ie: If I leave stock leaf springs but deep-tub, the springs are the limiting factor. Nevermind the frame rails and springs, but use the deep-tubs, how wide can we go?
      335
