    Results 1 to 6 of 6
      Oct 2006
      Morristown, NJ
      C5 Brake Pedal Ratio?
      What is the brake pedal ratio on a stock C5 Corvette?
      1973 Camaro Type LT/RS
      http://www.apiem.com/camaro
      Quote Originally Posted by amargari
      I asked this on the corvetteforum about a year back and got a couple different people to say 3.5:1
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Oct 2006
      Morristown, NJ
      That seems close to the 3.35 ratio I quickly calculated on my 2nd Gen Camaro. I will have to pull my pedals out of storage and double check my calculations though.
      -Thanks
      Oct 2006
      Morristown, NJ
      After pulling the pedals out of storage, it looks like the ratio is more like 3.3 to 1. I hope this works out ok.
      Jun 2002
      Benicia, CA
      My 71 Camaro pedal ratio is closer to 5.2:1 (manual brake setup). Using the new pedal pad that I will be installing (aluminum), which hangs lower and therefore creates a slightly longer pedal center, my new ratio will be about 5.5:1.
      Jeff
      1971 RS Camaro: PAINKILLER
      Oct 2006
      Morristown, NJ
      This is a power brake setup.
