    Results 1 to 9 of 9
    Thread: intro's on 69?
      NEBRASKA !!!
      intro's on 69?
      I am leaning towards dropping my 1969 camaro down and going with the intro (Matrix) wheels? I will not be mini-tubbing? But I will go with 3" DSE drop leafs in the rear 12 bolt standard rear end. Also 2" drop springs in the front. The car will have a BBC under the hood. I read that drop spindles are not the preferred choice, Right? Anyway what are the largest and widest wheels and tires I can go with on front and rear? I have read alot of posts and there are so many conflicting answers and ideas I am confused?
      I would like to go:
      front: 17 X 8
      rear: 19 X 10 with correct backspacing?
      Could someone help me out on this issue.
      Mar 2003
      Lafayette, In.
      Quote Originally Posted by Dundee
      I would like to go:
      front: 17 X 8
      if it was me, i'd go 18f and 19r
      Sep 2004
      Metamora, Illinois
      Quote Originally Posted by TRILOGYZ28
      What he said or go with 18s all around
      NEBRASKA !!!
      Is it possible to stuff a 17-18 X 10" wide under the rear without mini-tubs on a 1969 camaro? What are my limits?
      Jun 2005
      Omaha, NE
      I personally would "not" go with a 10" wide wheel. You can fit a 275 on a 9" wheel and have a nice safety margin.
      I also agree with a 18f and 19r.
      No dropped spindles! Stick with lowering springs "less expensive" or switch to coilovers "more expensive".
      Jeff
      Jun 2006
      Indianapolis,IN
      I will agree 18x9 is about as wide as you can go. I know some do not like this look but you can get a 20x8.5 under a 69. Tim
      nw arkansas
      i did a 67 last month , all i could fit under it and not have it sticking out in the fender was a 8.5 with a 5.5 back , 20x8.5 with a 5.5 and 19x8 with a 5 back .
      Cookeville, TN
      I stuffed 18 x 10's with a 275 tire on my '69, but it has 2" drop DSE springs. The tires do rub at times. So with a 3" drop or if you drive very aggressive, I would go with 18 x 9.
      NEBRASKA !!!
      So if you roll the lip up on the fender and you drop 3" w/DSE springs it is possible to go 18-19X10 in the rear? If thats ok what length would be best for backspacing? Sorry about all the questions but these wheels are expensive and I would like to get the order right the first time.
