    Results 1 to 20 of 24
      IN/MI border
      Gold coat/Zinc coat... where to get it done?
      Hey guys, I have my window hardware pulled out of the doors on the '68 camaro. I wanted to send it somewhere that can dip this stuff, clean it up and zinc/gold coat it. Not sure what else you call it. Anyway, just wonder if there is any good places to get this done and about how much it costs to do so?
      Buddy P
      Jan 2002
      Italy
      I have no idea where you can do it in your area, but I like the zink coating best and it keeps up very well.
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      Apr 2004
      OKC, OK
      Check with your local plating shops. If none, should be one in Indy or Detroit that can. Cost here runs about $4 per pound.
      Mike
      Mike Redpath
      Musclerodz & Customz
      405-288-0189
      pro-touring parts specialists
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Boonville, Missouri
      Northern Plating - Madison, WI
      I had all my pieces electroless nickel plated. They do yellow zinc as well.
      Tony Edler
      Illumin8s
      '73 Dodge Challenger
      Mountain View, CA
      Cad plating is another option you might explore as well.
      True T.
      My blog
      IN/MI border
      Quote Originally Posted by Damn True
      What's the difference? Teach me please!
      Mountain View, CA
      A different material. Cad or Cadmium is a anode plating. It's the gold/tan mottled stuff you see on a lot of aircraft hardware. It is intended to be used in dissimilar metals applications (bolting an aluminum or magnesium thing to a steel thing). Essentially, the Cad is the material with the highest electrical potential so it gives up it's electrons first (corrodes) and mitigates the corrosion of the steel or aluminum.
      True T.
      My blog
      Sep 2004
      Kettering, OH
      I believe the gold/green/tan finish on aircraft aluminum is Alodine, a hex chrome conversion coat, not a plated finish.
      Cad is an alternative to zinc and was factory finish on brake boosters and other hardware. It can be silver or yellow if an additional hex chrome process is done after plating. Cad is a little better sacrificial coating than zinc, but is much more toxic and has been outlawed in most places. I deal with a place in Dayton Ohio that does both zinc and cad and will also do yellow zinc and yellow cad. They are also very reasonable: B-N Plating, 937.228.2963.
      1967 Firebird Convert, Fuel Injected 462 ci, TKO 600
      http://1967firebird.atwebpages.com
      Aug 2005
      Hamilton, NJ
      Check caswell plating for home kits.
      Scott from NJ.
      Vent Windows Forever! ...
      Sep 2004
      Kettering, OH
      I have the Caswell kit. If you're only doing rotors have someone else do it.
      Apr 2004
      OKC, OK
      The gold on cad or zinc is an irridite that allows paint to adhere to the plated part as alodine does for aluminum. original parts were clear (referred to as silver). IF you cad or zinc plate the assemblies, have them baked to removed embrittlement from the springs. If not, you might get a suprise when you stress the spring. Another alternative would be to tin flash.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Mountain View, CA
      Quote Originally Posted by Hammered
      "Alodine" is a process where you first acid etch the AL and then apply the Alodine conversion coating (chromate). Alodine is a strong oxidizer and does a chemical conversion of the surface (oxidizes it).
      Alodine essentially creates a barrier to further corrosion. Sort of a man made version of the natural patina that develops on bronze or copper.
      True T.
      My blog
      Jan 2002
      Italy
      hey true,
      are you this smart or do you use google as us other guys?
      Have Fun!
      André
      IN/MI border
      When this process is done (zinc, alodine, etc.) does it eat into rubber/plastic?
      Mountain View, CA
      Quote Originally Posted by Tigergutt
      hey true,
      My previous career was in the Coast Guard and managed aircraft maintenance. Alodine and CAD plated hardware were daily use items.
      I'm not especially smart, but I've been around a bit.
      True T.
      My blog
      Socal, Ca
      Can we see a picture of what you guys are talking about?
      IN/MI border
      Here's some of the stuff I want to get dipped/cleaned/coated...
      Apr 2004
      OKC, OK
      That looks to be galvanized. I need to look at some regs I have here to verify. Cad will eat plastics. Alodine won't.
      Mike
      Mike Redpath
      405-288-0189
      Musclerodz.com
      facebook page
      instagram
      Musclerodz
      Mountain View, CA
      Yup, that is Galv
      True T.
      My blog
      IN/MI border
      I just want to get them redipped/coated or whatever. I figured zinc/gold coat would be the best thing to do?
