View Full Version : LSx engine 180 degree headers?
boodlefoof
10-01-2006, 05:13 PM
Hey guys,
I've been looking around here and on LS1tech and I was unable to find any information about whether 180 degree headers would be of any benefit on an LSx engine. I realize they use a different firing order than the Gen I engines, but would there be any benefit to be had by using some sort of crossover headers?
Clearance/space considerations aside...
chicane67
10-01-2006, 05:24 PM
You could alleviate any firing order issue by changing the individual tube location in the collector. So in effect, all the 180* header theory would still there.
Damn True
05-08-2008, 08:09 AM
So do we have anyone savvy in the ways of header building and the space constraints of an LSx/1st Gen Camaro that can tell us if this is doable or cost/difficulty prohibitive.
parsonsj
05-08-2008, 09:10 AM
First, does anybody know what the expected benefit is? How much hp gain are we talking about?
jp
Damn True
05-08-2008, 09:18 AM
Even if it was a wash (which it isn't) I'd still be interested, depending on price, based on the sound alone.
Chad-1stGen
05-08-2008, 11:26 AM
Ok I'm a nub. Care to explain the 180* theory?
Damn True
05-08-2008, 12:09 PM
This explains it for an FE. I think on a bow-tie you swap the two center cylinders from each bank.
parsonsj
05-08-2008, 12:18 PM
Care to explain the 180* theory?180 theory is that if you get the 4 primary tubes to a collector at 180 degree intervals then you make collector as efficient as possible.
Take the LS1 firing order: 18726543. So one collector needs 1, 7, 6, and 4; and the other gets 8, 2, 5, and 3.
As you can imagine, the fabrication/packaging difficulty of such an arrangement in a normal passenger car is substantial.
jp
Damn True
05-08-2008, 12:25 PM
Forgot the link:
http://home.alltel.net/bsprowl/Exhaust/180FEHeaders.htm
Jimmy Sean
05-08-2008, 01:02 PM
Here is a Corvette with 180 deg headers.
MSZTbR6C6Lw
Yelcamino
05-08-2008, 01:19 PM
MSZTbR6C6Lw
That sounded awesome! I need a set for mine! Any chance of knowing the brand of header?
Damn True
05-08-2008, 01:52 PM
I've seen that video before and ATI comes to mind. Could be wrong.
Mike Norris
05-08-2008, 01:57 PM
Come on John, we can build a set, I ain't scared. Be a hell of a project.
Packaging is always a bear with any front mounted engine in a stock style chassis. We used them a lot in late model stock cars and modifieds where the chassis is svery wide open.
I can not imagine that Corvette has tubes shorter then 40-45" to make it work.
Mike Norris
Jimmy Sean
05-09-2008, 06:16 AM
I believe this thread is speaking of the car in the video.
http://forums.corvetteforum.com/showthread.php?t=1323232&forum_id=1
parsonsj
05-09-2008, 07:28 AM
Come on John, we can build a set, I ain't scared. Be a hell of a project.You know with your facilities, I'm sure we can. All we need is a willing victim (err... customer). :)
We'd have to get 4 tubes across the bottom of the engine, and keep those tube lengths less than 40" I'd guess.
jp
Bow Tie 67
05-09-2008, 10:41 AM
That sounds wicked!!
Jimmy Sean
05-09-2008, 12:21 PM
I'm thinking outloud here. Do a two into one for each of the middle cylinders and then run a single tube to the other bank Sort of a Tri-Y, then at least you only have two tubes that crossing under the engine. Though each collector would be a three tube. Unless you pair up the out side cylinders for a tri-y also, then it would be a two tube collector.
How would that effect the sound compared to a conventional 180 degree header I wonder?
Damn True
05-13-2008, 11:44 AM
jp
If only I was at that stage in the build John.
....another benefit...or so I've read...is that you don't need as much duration in the cam to get good scavenging.
Just the same...if you guys show up with an LS and a bunch of tube you are more than welcome to use my Camaro as template.
wendell
05-13-2008, 12:29 PM
I believe the ASA cars ran 180 degree crossover headers. Howe builds headers and built the ASA chassis. amybe give them a call. For the life of me I can't see how they're going to work in a street car butthe do sound good.
Damn True
05-13-2008, 12:51 PM
I'm thinking you'd have to run the crossover just aft of the bellhousing and use a slip-joint and band-clamp.
"This one time.....at band clamp......"
rocketman
05-13-2008, 01:42 PM
MSZTbR6C6Lw
sounds to importy for me, I dont like it.
We used to run them circle track racing, and found a good set of crossover made more power.
I think a good set of equal lengths with merge collectors would be better.
DarkoNova
05-13-2008, 02:46 PM
At least I'm not alone. I don't think it sounds all that great, honestly.
Matt
Damn True
05-27-2008, 08:38 AM
In this months Car Craft there is a photo of a set of 180-deg headers on a smallblock. If you can get past the fact that they are on a pink Chevette that is doing a back-flip it's pretty telling in terms of what would have to be done to package them.
silver69camaro
05-27-2008, 10:32 AM
Matt
You gotta hear it in person. It's awesome and you'll recognize it every time.
chicane67
05-27-2008, 05:41 PM
Imagine the packaging issues with something similar to this:
https://static1.pt-content.com/images/pt/2008/05/IMG_1339-1.jpg
