View Full Version : Shock Lenght ?
osdmike
09-30-2006, 07:55 PM
Hi!
I have a problem with to short coilover shocks in the rear,...I think ?
I drove the car in a pothole,and the car bounced up ,and the left upper mount of the shock was ripped of.(see pic.)
I also got an oil leak.
I was thinking of putting in longer shocks ,for a longer bump-stroke ,to prevent that this wouldnīt happen again.
Are longer shocks better ?
What is the ideal shock length (coilovers) on a street/protouring-car?
I have a Ford 9" with 4-link , so I donīt mind ,making an improvement on the rear suspension , if itīs possible.
The length of the shocks are approx.14,5" (extended length)
If You look at the pic. , maybe itīs possible to use the existing , lower mounts.
Anyone had the same problem?
"Osdmike" -69 Camaro
redss86
10-02-2006, 04:24 AM
I would measure your shock length at ride height. Then find a shock that is compressed 1/3 of the way at this height, so that you still have 2/3 of the shocks travel for compression. If you set it up like this then you shouldn't have any problem w/ bottoming the shock out. Which sounds like what happened. As far as the ideal shock length, I don't think there is such a thing. I all depends on you available length.
Good luck and hope theis helps,
Joe
osdmike
10-04-2006, 04:54 PM
Thanks for Your answer.
These are SPAX coilovers (English made I think?),
but I think I will go for QA1 Hal Proma Star Single-adjustable ,
....or maybe KONI SPA1 (KON-802650SPA1), Double-adjustable , instead.
This car will mostly see the street.
Will any of these shocks do , do You think ?
Any other suggestions ? :hmm:
"OSDMIKE"
Tiger
10-04-2006, 11:59 PM
I think those koni's are dragrace only, i got cheapo and bought the qa1's for my car
osdmike
10-08-2006, 05:40 PM
Yeah.I think Iīll go for the QA1 Hal Proma Star too.
Thanks.
Osdmike
EFI69Cam
10-08-2006, 06:33 PM
Check out alston's varishocks before you spend your money.
I have not driven on mine yet, but they are 100% us made.
aonghus
10-08-2006, 08:56 PM
SPAX is English, what is the diameter of that shaft?
