View Full Version : Little Progress on 73 RS
Davezz28
09-30-2006, 02:09 PM
Thought I would post the progress on my 73 RS
I just finished painting the car about 3 weeks ago. It is painted BMW Titanium Silver with Black stripes. It was a factory silver car with black interior so I thought I would keep it close to original.
Just finished the motor & trans and got it installed today.
Specs on the motor are:
350 + .030 4-bolt block
GM Steel Crank
Wiseco pistons w/anti friction coated skirts, thermal coated domes & tapered pins
Scat H beam rods
Balanced @ 1811g bob weight
Edelbrock Perf RPM heads w/ 7/16 studs
Crane Variable ratio gold rockers
Perf RPM Int.
Comp XE262H cam
Plan on C5 front, LS1 rear brakes
175# 2” drop rear springs
650# front springs w/ AFCO adjusters
Bilstien shocks
I will leave the factory F41 suspension F & R sway bars
If all goes well I should make the Green flag track day at Buttonwillow in November.
72Z/28
09-30-2006, 02:37 PM
That is looking good, keep us updated with more pics, really want to see this bad boy when it's done..
Bandit
09-30-2006, 03:04 PM
Nice job, keep us posted with the updates!
XTRMEASURES
09-30-2006, 04:34 PM
i love thoughs cars
Todds69
10-01-2006, 07:12 AM
I miss my '73. Love the silver/black scheme.
WhiteG240
10-02-2006, 04:50 PM
Do you have any other pictures?
Davezz28
10-03-2006, 10:49 AM
I have a lot of pictures but they were taken during the bodywork/paint stage. I have not rolled the car out to take pictures yet. If all goes well I should have the front clip installed next week, I will get more pics then
Roger Poirier
10-04-2006, 03:31 PM
A little progress. It's already been painted. You are down to install only.
Piece of cake. I like the colors. Keep up the good work.
R.P.
73z-6sp
10-04-2006, 05:27 PM
Yea! Looks great! I love the 70-73 Camaros.
Keep up the good work. I love the silver and black too.
twosaturns
10-05-2006, 10:21 AM
looks good, nice to see the factory AC (considering most guys ripped them out over the years). I should be posting shots of my brother's '70 RS up here soon.
TEDDYS CAMARO
10-05-2006, 11:46 AM
Looks Good.
Orngcrush69
10-16-2006, 07:03 PM
hey...where are all the pix you've been taking?
BonzoHansen
10-17-2006, 04:54 PM
Woo-hoo!
orbit
10-18-2006, 09:39 AM
Man 'o man.... I want a '70-'73 Camaro. You absolutely NEED to post you'r pics ASAP!!
Davezz28
10-21-2006, 05:14 PM
Well, here is another pic of the underside of the car. The thing is you can spend a ton of hours doing the grunt work (cleaning off 30+ years of grime) and it does not look like you are making much progress.
I got the under side cleaned up and painted, rear susp. and rear end pulled and exhaust hung. I also got the motor wiring all finalized.
I put a flowmaster exh system on the car, and I have to admit they have a well fitting system. I have come to expect that "kits" don't really fit, they are a short cut for complete custom fabrication. This kit or system FIT. With a little cutting and welding it went in perfect, I would recommend it if you like the flowmaster sound.
Not too exciting but here you go.
And Dave H., don't for get to bring the roller next week so we can get the dynamat installed.
DaveG.
WhiteG240
10-22-2006, 09:19 AM
Get a little carried away on the paint?? lol The top of the jackstands are painted to match the car. ;)
Davezz28
11-29-2006, 09:33 PM
Finally got some more part in and thought I would post some more pics.
Got the front C5 and rear LS1 brakes installed
GW Del-A-Lum LCA bushing and BJs installed
Just got the Pole position UCAs in and installed the springs and shocks.
Got the tires mounted on the Billet Specialites Qualifer wheels
Waiting on a couple more part, then should be hanging sheet metal
70CaliCustom
11-29-2006, 10:54 PM
Nice Car, I love the color as well.
What master cylinder are you planning on using with the C5/LS1 brake combo? Also, if you don't mind me asking, how much is the brake setup running you so far? I'd love to do that to my 71 as well.
Thanks!
tomspo04
11-30-2006, 06:29 AM
Dave, Very NICE! How expensive was it to go to the C5/LS1 brake combo? Excellent color combo, too!:6gears:
Davezz28
11-30-2006, 06:51 PM
It does not take a ton on money to install the C5/LS1 set up if you search around for some deals.
On the rears I am not sure exactly how much I have invested because I had a lot of the part for some time now and can’t remember what I paid for them. To do it right, you will need 2 left backing plates and 2 left calipers. I use the factory parking brake cables and modify them to work. If you bought the parts through GM parts direct you might have $500 less rotors in all new parts. If you searched on ebay for deals on calipers you could do it for less.
On the fronts, I machined a 3rd gen Camaro rotor into a hub, used a set of low mileage calipers from a C5, local auto parts rotors, brackets and hoses from Kore3. Even with new calipers you should be able to do the set up for $500 with a little work and fabrication.
It’s all the little stuff that costs, like replacing ball joints, bushings, bearing, seals, and all the other stuff you see worn out when you have the thing apart.
tomspo04
12-01-2006, 04:22 AM
Thanks for the info! Looking forward to see your progress. I've been in love with 2nd gens for many years. My 1st was a 73 Z28 (wish I still had it) and the one I have now is a 70 SS. They not only look great, but are a great platform.:6gears:
Davezz28
02-14-2007, 05:30 PM
Finally got the paint cut and buffed, interior installed. Just about ready to take for a cruse
Steve1968LS2
02-14-2007, 05:39 PM
Sweet!
Let us know when she is all done.. and more pics (we always want MORE pics.. lol)
camaro608
02-14-2007, 07:16 PM
sure is a nice car
i love tem pretty camaros
no really very nice car
brink_79camaro
02-15-2007, 09:28 AM
Very nice looking car!!! I can't wait to see my 79 that far along. Keep us updated.
Davezz28
03-07-2007, 01:39 PM
Took it out for a drive finally and it runs pretty good. Got all the rest of the lights and stuff on and all the grill work. Gona get it registered next Monday and then take it out for a little shake down.
She is almost ready to sell.
73z-6sp
03-07-2007, 02:46 PM
Man! That is a nice car! I love the 70-73's. They're the best if you ask me.
protour73
03-07-2007, 06:20 PM
Keep up the great work.............................from another 2nd Gen fan!!!:naughty:
Motown 454
03-07-2007, 07:47 PM
Car Looks realy nice, you did a nice jod putting it back together !
Mr.VENGEANCE
03-07-2007, 09:43 PM
without the grille looks like its rabid.
TEDDYS CAMARO
03-09-2007, 10:09 PM
Looks great! I like the color.
Footjoy
03-27-2007, 06:29 PM
Man I love that car. But I'm 6'4 and don't fit so well.
73z-6sp
03-27-2007, 08:06 PM
Whadya mean you dont fit so well? I am 6.4 also and I fit fine in my 73. Now the 68 I have now is a different story!
