View Full Version : Corvette C4 angle?
Tiger
09-29-2006, 05:44 AM
Is it right to suppose that the halfshafts on my Dana44 c4 corvette rear are to point straight out (seen from above), or should I point them a some degrees rearward rearward to be sure to always have an angle at the u-joints?
thanks!
10-01-2006, 09:51 AM
Hi Andre,
how ya been?
I had 2 up on the 4 post rack for inspection for the same reason. It seems factory had a slight angle rearward (3-7 degree). Most likely for u joint life and NVH. Are your half shafts stock or narrowed?
Tiger
10-03-2006, 10:47 AM
Hey man, its been a while:cheers:
Its an 85 rear and its not narrowed.
To me it looks like hub is to be 1 3/4" rearward compared to the center section.
I havent measured any degrees though.
orphancars
10-29-2006, 08:17 AM
thanks!
Andre/MrQuick,
I'll be out in the shop to check this, but doesn't the lower link that goes between the diff and the hub assembly set that angle for you?
thx,
-jeff d
Tiger
10-29-2006, 01:01 PM
Thanks Jeff,
Unfortunately it doesnt as you are able to move the hub several inches if its not set to the car.
I appreciate your effort!
orphancars
10-29-2006, 09:16 PM
Just a follow-up..........
Set up the suspension on my chassis table, and there is indeed a ~3 degree sweep rearwards on the suspension. The lower control arm that goes out from the diff to the hub locates things pretty solidly. I didn't notice any movement/deflection fore/aft. Comparing all my other measurements that I took from a stock C4, I'm pretty sure that I got everything assembled properly.
Like I said, maybe I'm missing something, but it looks like there is a little rearward sweep to the halfshafts. That intentional misalignment coupled with the slight (~2 degree) "droop" in the halfshafts is all probably there intentionally to keep the u-joints happy.
-jeff "reverse engineering is fun!" d
Tiger
10-30-2006, 10:02 AM
Cool Jeff, thank you!
I appreciate it
