    Results 1 to 8 of 8
      17x9.5 fit 1972 A body ?
      hi new here have a 1972 chevelle with 17x8 all the way around want to go as big in back as possible with out cutting the car up.any help out there if a 17x9.5 will fit ? thanks
      Nov 2002
      Georgetown,TX
      17x9.5's with 5.5" backspacing will fit 68-72 Chevy A-bodies like a glove,front or back. With 5.75",they will do the same for 66-67's.
      RI
      Yea what clint said, thats what I have on my 70 lemans with a 285/40 tire
      Frank M
      1970 lemans sport
      2005 srt-10 ram
      http://www.youtube.com/watch?v=SER1gBLn2N0
      Apr 2003
      Central Valley, CA
      17 x 9.5 will practically fall into the rear wheelwells-- yes, they will fit. 17 x 11 is typically not a problem either if you measure properly.
      The 9.5's will also fit up front.
      1969 Chevelle
      Old setup: Procharged/intercooled/EFI 353 SBC, TKO, ATS/SPC/Global West suspension, C6 brakes & hydroboost.
      In progress: LS2, 3.0 Whipple, T56 Magnum, torque arm & watts link, Wilwood Aero6/4 brakes, Mk60 ABS, vaporworx, floater 9" rear, etc.
      Oct 2005
      Ferndale, WA
      I believe the blargest size you can go with is and 17x11 with 6.75 backspacing, tires size is a 315/30/17. This measuring has to be dead on with the backspace so make sure you measure so you don't have a set of pricey paperweights. Goodluck
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
      thanks for the help. cool elchevelle had a 1970 i miss it. thanks again.
      thanks for the help.car sounds cool!!!!
      thanks for the help , idont think i am doing this reply thing right.
