    Results 1 to 6 of 6
      Atlanta GA
      Finished the Minitubs.. what did you guys do for your rear seat?
      so the seat is too big now.. what solutions did you guys do for this?
      i searched but not too many good results..
      whats the move?
      Phoenix,AZ
      there was something on Super Chevy that show what DSE did for back seat.
      Los Altos CA
      my advise, get yourself a BFH and goto work! all you need to do is work the frame in and the foam should take care of itself
      BFH=Big F***ing Hammer
      Mar 2002
      Redwood City, CA
      Heh... Funny Brian. It might work like that, but really you should cut the seat frame and route it around the tubs.
      Allen Ortega
      Coolidge, GA
      We simply cut and rewelded the outer edges of the frame around the tubs. Not to hard to do really. Just strip the covers and foam off the frames. Lay the frames in there and you'll see right away what needs to be cut. You are going to cut out a portion of the frame that is vital and the seat structure will be compromised if the frame is not welded back up and strengthened in the cut areas
      Greenwood SC
      Are there pics somewhere of where to cut and weld, I need to send seats to get recovered and the car is at the body shop 3 hours away
