View Full Version : PCV inside a AN hose or fitting?
Tiger
08-29-2006, 01:12 PM
Hi,
from my one valvecover to the intake manifold I'll run a PCV valve but I'd like to hide it inside an AN hose or fitting to avoid using the ugly rubber grommet, have any of you tried this??
are there different sized PCV valves around?
thanks!
John Monnin
08-29-2006, 05:11 PM
Use a crankvent, its a fancy bilet aluminum PCV valve.
They have a AN connection version but its not shown on thier webpage
http://www.et-performance.com/turbo.html
Tiger
08-30-2006, 12:33 AM
thanks, looks like what I need, but at a whoppin $110!!!!!
I might end up getting it if I cant find anything cheaper but other ideas are welcome.
John Monnin
08-30-2006, 05:12 PM
EDIT: A PVC valve is NOT the same as a check valve, soory for the bad idea:(
Isn't a PCV valve just a ball check valve? search mcmaster Carr
https://static1.pt-content.com/images/pt/2006/08/pcvoperation-1.gif
http://www.mcmaster.com/
Tiger
08-31-2006, 01:06 PM
thanks, I'll look into that:doh:
John Monnin
09-01-2006, 04:41 PM
The crankvent sellers claim that the crack pressure and opening speed is critical, I have no clue
Tiger
09-02-2006, 02:26 AM
wow, that I dont know..... but a ball valve should be pretty fast as well...
but I know that without any valve in case of an engine backfire it might ingnite the crankcase gases and blow the thing apart..... :drive2:
Tiger
09-05-2006, 04:53 AM
Ordrered a 3/8"npt stainless ball check valve from Mcmaster today, thanks for helpin!
jaybee
09-07-2006, 06:01 AM
I don't think you want to do that. Please see here: http://www.jalopyjournal.com/forum/showthread.php?t=61376 it explains the PCV system thoroughly complete with a cutaway PCV valve and an explanation of how it works.
Tiger
09-08-2006, 12:40 AM
Thanks for replying, I read the article (very nice) and didnt find the reason to not use a ball check valve.
is is due to the different flowing rate of the pcv at different vacum?
thanks!
jaybee
09-08-2006, 07:15 AM
Yes. I believe your engine will see a massive vacuum leak at idle. The PCV actually flows LESS under high vacuum (idle) and MORE under low vacuum (wot or heavy load) because the shuttle inside the valve is pulled farther into the orifice with increasing vacuum.
Tiger
09-12-2006, 08:15 AM
considering that you are probably right.
Since I already have it I'll give it a try anyway and see if it causes a major vacum leak.:hand:
John Monnin
09-12-2006, 05:06 PM
Sorry about the bad information, thanks for the good link on PVC valves!
I felt so bad for leading you astray that I went to the autoparts store and they let me look through thier selection of PVC valves.
Purolator PV1020 looks like 2 barbed hose ends butted together. One end is made for a 1/2" diameter hose and the other end is made for a 3/8" diameter hose. The biggest part of the body is .594" in diameter.
You might be able to slipit completely inside a #10 AN hose.
If you turned it down on a lathe or even just filed it down in the center it would definitely fit completely inside a #8 AN hose
CarlC
09-12-2006, 08:03 PM
Take a look on my website at the engine picture. In the LH valve cover I use a modified AN "el" that has a GM PCV check ball setup installed. I purchased it from a local hot rod shop. I know where it is but I don't remember the name. If interested, I can stop by there next week and find out if they still carrry them.
Tiger
09-13-2006, 01:12 AM
thanks guys, I might eventually just buy the one from et performance.
or a ground down pcv insice a hose...
I'll ask my buddy in SF if he can drive by an auto parts store and get me a Purolator PV1020.
thanks for helpin
parsonsj
09-13-2006, 05:04 AM
Have you looked at Earl's breathers?
Search on pn EAR-3434116ERL at www.summitracing.com
jp
Tiger
09-13-2006, 06:29 AM
yeah I have looked at it but I do not like it, ts not to be a picky ass but I dont want the grommet style....
I do indeed really appreciate your suggestions here
As for now the idea is to have one AN-10 weld bung in each valve cover, then stick the PCV inside the AN-10 hose that goes to the manifold (as John suggested), the other AN-10 would go to a Moroso breather tank on the firewall.
BonzoHansen
09-16-2006, 08:44 AM
Carl, that is clean.
This is the best pic I see: http://www.geocities.com/casanoc/alt_1.JPG
I've always liked those covers. Did you have any problems with the PCV setup and oil? I've had issues in the past with non-baffled covers - PCV draws oil mist in, and oil out the breather too. But I never tried taller ones like those.
eville
10-02-2006, 10:58 AM
I'd be interested. That is a sweet setup!
syborg tt
10-03-2006, 11:42 AM
is there any reason that you couldn't mount it the verticle surface on the back of the valve cover.
Tiger
10-09-2006, 04:11 AM
Hey John,
My buddy Ed couldnt find the a small enough pcv, he sent me two 13/16" diameter ones though.
are you able to get me one of those PV1020's and send it to me? , I can paypal you the $$
pls let me know.
thanks!
John Monnin
10-10-2006, 03:02 AM
Give me your address and I'll mail one to you. No big deal it was really cheap
Tiger
10-10-2006, 12:25 PM
thanks John.
I sent you a PM
CarlC
10-10-2006, 06:29 PM
Sorry guys, I've been busy lately. I'll try and get by the shop soon.
The covers do have internal baffling.
Rick Dorion
10-11-2006, 06:45 AM
Did you add the internal baffling, Carl?
