View Full Version : Provair's engine is almost done.
TonyL
08-27-2006, 10:18 PM
Time for an update.
From this dirty nasty engine:
To this:
modded oil fill, I used a freeze plug to fill the hole the original neck was in, and a boat plug as a new oil cap in the former fuel pump spot, I removed the original filler neck that sticks up about 8 inches. The original design just looked horrible. I've also used a 90 degree adapter so the filter is easyer to change.
it's supposed to look like this.
https://static1.pt-content.com/images/pt/2006/08/engine-1.jpg
I'l have it in this weekend.
CRCRFT78
08-28-2006, 08:29 AM
Looking pretty good Tony. I've seen some nice Corvairs floating around from time to time but not to many. Keep the pics coming. Bet you can't wait to hear it start.
chuntington101
09-01-2006, 12:31 PM
what engine are you putting in???
Chris.
brrymnvette
09-01-2006, 12:37 PM
That thing needs one of these. :3gears:
TonyL
09-01-2006, 12:56 PM
its a 140 that's been punched out .60 over, hot cam, ported heads, worked carbs and electronic ignition. Should put out over 180 to 190 hp. dont sound like much? dont forget how light the engine is, as well as the car.
It takes a sizeable hp small block to make up for the weight gain. It'll be just enough this way. Im not willing to sacrifice the back seat for an engine.
brrymnvette
09-01-2006, 01:09 PM
That's why I skipped the small block:revto9k:
Turbo that thing then. They made a turbo kit for it back in the day I thought.
TonyL
09-01-2006, 01:25 PM
Actually the turbo sucks. Its horrible to drive. It only has the "180" hp when in boost above 3500 rpm. otherwise it's only pushing 85 hp. And that's HORRIBLE.
The real trick is to take todays turbos, throttle bodys, and fuel injection and then introduce them to my little six cylinder friend here.
Plans are already in the works. that or a procharger.
Kenova
09-01-2006, 05:51 PM
:jump: Damn Tony, now yer talkin' !!!! I've seen a couple of Vairs turbo'ed with a modern carb and turbo. The owners said that the old system couldn't hold a candle :candle: to the modern stuff. The engines were also better built to handle the boost. One owner was happy enough with the Holley four (draw through) that he tossed his plans for injection.
Ken
ill steez
09-01-2006, 10:36 PM
how much does the little feller weigh? looks awesome.
Steve1968LS2
09-02-2006, 06:44 AM
wow, quite a transformation..
The key seems to be power to weight..
TonyL
09-02-2006, 08:06 AM
the car? just about 2000 lbs. (one with a crown v8 is 2750 lbs) the corvette of the era weighed 3700 lbs.
the stock engine and transaxle is only 450 lbs.
chuntington101
09-06-2006, 10:53 AM
hummmmm scooby engine might fit in there!! ;)
Chris.
nekkidhillbilly
09-15-2006, 12:23 AM
how about a fwd car engine tranny i think that would be neat in one
