    Results 1 to 3 of 3
    Thread: rear disc 70
      Aug 2006
      rear disc 70
      have 70 chevelle with 12 bolt rear end and have a complete rear out of a 2000 camaro with discs.Would it be possible to put the camaro discs on the 12 bolt and if so what else would be needed.
      Call BRP they have adapter brackets to get those on early GM 10 and 12 bolts.
      http://www.brphotrods.com/
      1967 Camaro RS, LS1, D1SC DSE Mini-Tub, TH350, 12 BOLT 3:73.
      Marshall , MO
      They bolt on the only thing you might need is a spacer between the axel flang and the caliper bracket. You will need longer bolts for the caliper bracket. Then you need to figure out the ebrake cables.
      Brad Shepard
      69 Malibu
      Marshall, MO
