    Results 1 to 6 of 6
      Apr 2003
      So Cal
      Test fitted the rear wheels.....(pics)
      The tires are 295/30/19. Im extremely pleased with the look and fit. They fit perfectly inside the wheelwell with no mods. I think the 19" rims worked out well, they dont seem to big for the car.
      Now all I need is paint, engine, interior, suspension, brakes.....
      73 Camaro Type LT
      Greenville, IL
      Is that all? I still have all that plus wheels/tires :(
      Wheels/tires look great. Did you measure the backspacing yourself or have it done. If you did it, great job, and keep up the good work.
      Joe
      Atlanta GA
      Feb 2006
      Brampton, Ontario, CANADA !!
      Looks good on there. Will you have enough clearance when it's going down the road? It looks like it might be a bit tight when cornering and / or hitting a large bump, depending on how much movement and travel your suspension is going to have.
      cheers
      Ed N.
      Ed Nicholson
      73 VW Super Beetle "Sports Bug"
      95 Taurus SHO 5-speed -- new open-track beater
      Apr 2003
      So Cal
      Quote Originally Posted by jmarti81
      Joe
      I had a bolt on spacer made so the wheels would fit correctly. When I got the wheels I knew I would need a spacer because of the backspacing, so all i did was place the wheel in the wheelwell where I wanted it and measured the space, then had the spacer made. Worked out pretty good.
      73 Camaro Type LT
      Apr 2003
      So Cal
      Quote Originally Posted by fast Ed
      cheers
      Ed N.
      From what I can see there should be enough clearence, especially on the inside. The outside looks close in the pics, but it shouldnt be a problem. If anything I could just roll the lip a little bit if I have to, but I dont think it will be necessary.
      73 Camaro Type LT
