View Full Version : Test fitted the rear wheels.....(pics)
vince
08-15-2006, 11:31 PM
https://static1.pt-content.com/images/noimg.gifhttps://static1.pt-content.com/images/noimg.gifThe tires are 295/30/19. Im extremely pleased with the look and fit. They fit perfectly inside the wheelwell with no mods. I think the 19" rims worked out well, they dont seem to big for the car.
Now all I need is paint, engine, interior, suspension, brakes..... :crying:
redss86
08-16-2006, 04:00 AM
Is that all? I still have all that plus wheels/tires :(
Wheels/tires look great. Did you measure the backspacing yourself or have it done. If you did it, great job, and keep up the good work.
Joe
Mr.VENGEANCE
08-16-2006, 06:33 AM
looks nice!
fast Ed
08-16-2006, 06:48 AM
Looks good on there. Will you have enough clearance when it's going down the road? It looks like it might be a bit tight when cornering and / or hitting a large bump, depending on how much movement and travel your suspension is going to have.
cheers
Ed N.
vince
08-16-2006, 10:33 AM
Joe
I had a bolt on spacer made so the wheels would fit correctly. When I got the wheels I knew I would need a spacer because of the backspacing, so all i did was place the wheel in the wheelwell where I wanted it and measured the space, then had the spacer made. Worked out pretty good.
vince
08-16-2006, 10:39 AM
cheers
Ed N.
From what I can see there should be enough clearence, especially on the inside. The outside looks close in the pics, but it shouldnt be a problem. If anything I could just roll the lip a little bit if I have to, but I dont think it will be necessary.
