    Results 1 to 11 of 11
      Albany, NY
      What is YOUR firewall made from??
      I just started making the templates for my custom firewall for the Novacane project. The factory firewall has been completely removed and I am starting from scratch.
      I don't know if I should use aluminum with beads rolled in it or if I should use steel. I think the aluminum would be to light but would look real clean. The steel would be a tougher piece!
      What do you guys think??
      Howard
      62' Chevy 2; AME 2" x 4" chassis with C5 front end, Triangulated 4 bar rear, Ford 9" Rear, 427 cu Twin Turbo LS1, Custom T56 Tranny OUT! 4L80E now going in!, BIG STUFF 3 DFI, Sheet metal intake
      www.lateral-g.net/tanner
      99' C5 w/ 420 cu motor, 538 RWHP/515 RWFT
      02' Denali P/U with Quad Steer
      Winters,Ca
      reply
      i would assume that the aluminum would let alot more of the heat into the cabin but then again im no expert and that would be a little sacrifice for something that would look really cool
      Nick
      La La Land, CA
      Mine is made of tin foil and paper bags.
      No, really it is made out of a sectioned steel wheel barrow tub.
      Tyler
      Alta Loma,SoCal
      Quote Originally Posted by TitoJones
      Tyler
      I thought i saw you steal my wheelbarrow!!
      Use steel. If you want to, roll some beads in it.
      1965 Buick Skylark
      wow
      wow a wheel barrow tub is a great idea. looks very nice.
      Laurens, SC
      Oil Pan
      I used part of a Ford 302 oil pan on my camaros firewall. Gave a nice recess for the distributer. I will have to see If I can dig up some pics.
      The wheel barrow tub looks awesome!!! Nice work!
      Jun 2001
      Orlando, FL
      I'm using 16g 1018 steel.
      jp
      ​John Parsons
      Miami, Florida
      I wish I knew.......
      I'm sure it's made of 100's of thousands of lines of text, commands, symbols, and alot of computative jargon!!!
      Kevin.
      69 Firebird "Eternity"
      Jul 2003
      Anaheim Hills, CA
      Mine is made from two sheets of 18 guage steel
      http://www.z069.us/69/Sent_to_HRCS/HRCS92.jpg
      1968 Track Rat Camaro:
      dennis68 Guest
      Keep in mind, do you want a bulkhead or a firewall? A bulkhead is what most vehicles have between the engine and cabin, if you want a firewall it should be at least 16ga steel if not thicker and some fireproof matting would also help.
      Mine's made from whatever the factory made it out of :D
