    Results 1 to 7 of 7
      Orlando, Fl
      Subframe Connector Solutions for 2nd Gen. Camaro
      As topic states.... Damn 2nd gen's and their lack of aftermarket support compared to 1st Gens... :comp3:
      May 2002
      Northern California
      connectors
      how soon do you need a pair? I will have something next year...mean while Chris Alson has a nice set up...they don't hang down too far.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Pittsburgh, PA
      Lack of options???
      Man you definitely havent been shopping hard:
      1. Global West
      2. South Side Machine
      3. Alston Race cars
      4. Competition engineering
      5. Jegs "Jegster"
      6. Chris Alstons Chassis Works
      You should also think about joining the forum at www.nastyz28.com.
      12,000 members should be able to answer anything you can throw at us.
      Take care,
      Shane
      Edmonton, Alberta, CANADA
      I am on NastyZ28...
      I have copies of the plans that Art Morrison made to build your own SFC's
      I am looking at building my own.
      FYI: I am noticing the 2nd gens are appearing on more and more magazines. I hope this is a trend, and therefore creating more aftermarket support. I have a '73.. and it seems that 70-73's are harder to get parts for than 74-80's
      Mar 2003
      Boringville
      use the alston racing connectors, they connect from frame to frame, not leaf spring pocket. THey are also low pro, i welded and bolted them in.
      IL/TN
      check out my web sit and click on suspension I have them in stock,keep in mind it's a new site under construction but you'll find what you need.www.pro-touringf-body.com
      Dunwoody, GA
      sweet. a new source for parts.
      anyway ive got the SSM connectors on my 79. nothing fancy and they hang low. im cutting them off. i need to get tot he front subframe bushings. i doubt ill be putting them back on. i want something that fits better and has more ground clearence since lowering is in the plans. on a positive note they are beefy as hell. they look like steel 2x4s
      Trey
      ~ Jon Hammond
