View Full Version : What steering column to use?
96Z28SS
08-09-2006, 12:37 PM
for my 69 camaro I want to replace the steering column with a tilt column.
What is better the flaming river or the I didit one.
Also what did you you guys do with the key ignition.
Mark Smith
08-09-2006, 03:37 PM
Ijust bought a ididit column thru gp store and it has the ignition in it.that is probably the main reason i went with ididit.it is a direct bolt in and you can choose how long you want the shaft.
parsonsj
08-09-2006, 04:34 PM
ididit for me too. I wanted the key in the dash, and they made it a custom length for me.
jp
J2speedandcustom
08-09-2006, 06:13 PM
We have used flaming river in the past I like their stuff for street rods. We have an ididit for a 69 we are currently building it's really nice. We did a chrome setup so it shines... :)
96Z28SS
08-09-2006, 10:17 PM
what ignition do you use if you don't want the ignition on the column.
The ididit column with the key doesn't look right to me. It doesn't look oe enough for me.
parsonsj
08-10-2006, 05:37 AM
what ignition do you use if you don't want the ignition on the column?AAW's wiring kits come with an ignition switch for the dash (just like OEM). I used their HiWay 22 kit.
jp
Madspeed
08-10-2006, 05:15 PM
Im CHEAP so i used a 2nd gen tilt colum
I took it completely apart replaced the ign switch lock cyl turn sig swith sand blasted all the pieces and painted it with a rattle can then wetsanded w 1200 and hand polished it
it also has flaming river stainless turn signal and tilt levers not shown in the photo wich aare about an inch shorter and fit nicely with a smaller diamiter steering wheel
73novaguy
08-11-2006, 04:30 PM
I used the Falming River unit in the Nova. I rewired the car using Ron Francis harness and actually deleted the ash tray by welding it flat and installing the key in it. That way when the car is on or off I can flip up the ash tray and the key is gone. Cleans it up a bit in the car. just my .02
67 455 Bird ragtop
09-14-2006, 09:01 AM
I have heard that the Ididit versions use the original mounting hardware. What all do you actually reuse on a 67 ?? I know there are mounting brackets that mount to the steering wheel that attach to the under dash bolts. Also there are pieces that cover the bracket on teh steering wheel. Are all of these pieces reused on the Ididit models so it looks like a stock mount ??
parsonsj
09-14-2006, 11:21 AM
67 what? Based on your username, I'm guessing Firebird, so I can't help you.
On my 67 Chevy II, all my stuff was custom fabricated: column to firewall, column to dash, column to steering wheel adapter, etc.
jp
