    Results 1 to 5 of 5
    Thread: tpi trannys
      livermore ca
      tpi trannys
      when i bought my car it came with a tpi 700r4 i was woundering if any one is fimilular with the company? and if any one knows the # to the company
      https://www.pro-touring.com/forum/sh...ad.php?t=22724
      65ss chevelle
      95 lt1 LE2 heads gm847 cam, 1.6 gold sereis roller rockers,52mm tb,37lb racetronix injectors. hooker headers
      63ss nova
      350:cam headers,roller rockers.pete jackson gear drive,
      th350 shift kit 3,500 stall
      3:73
      **Drive it like you stole it!!
      Mantorville, MN
      You sure it wasn't from TCI???
      livermore ca
      ya i found one site that sells them for 1400 doller so i tried callig them but the number dose not work and the web site was last updated in 03. i need to know if its an electronic tranny or not
      65ss chevelle
      63ss nova
      3:73
      Nov 2004
      Roanoke, VA
      Quote Originally Posted by lt1chevelle
      Several easy ways to find out....
      Pop the hood and look for another cable attached to the carb/throttle body other than the cable that connects to the gas pedal and/or cruise control. If there is a cable (called a TV cable BTW) that goes from the carb/throttle body down to the trans on the passenger side its a non electronic 700R4 trans.
      If youre already under the car look on the trans for a round multi pin electrical connector. If you find one then its electronic trans or 4L60E (the other name for electronic 700R4). If you find a four pin square electrical connector its a 700R4.
      If its the stock trans from the TPI donor car then its a non electronic 700R4.
      To sum it up:
      TV cable=700R4 (non electronic)
      4 pin electrical connector on the drivers side of the trans=700R4
      No TV cable=4L60E (electronic 700R4)
      Round multi pin electrical connector=4L60E
      GMC Syclone (currently wrecked thanks to the typical rubber headed VA driver not paying attention to his red stop light...oh and he didnt have insurance either)
      #614 11.9 @ 113
      New stuff finished 08/06:
      4L80E trans w/TCI PCM
      Front: J&S UCA/LCA, QA1 coil overs
      Rear: Caltracks/Belltech drop leaves
      Empire drive line alum drive shaft
      Polished 17x9 F/17x11 R ZR1s with 275s/315s
      Syclone
      Tow rig
      livermore ca
      Quote Originally Posted by myclone
      To sum it up:
      thanks but the tranny is not from a tpi car the maker of the tranny is TPI performace. but ill look at the following things here is a site
      http://hotterrods.com/search_results...rch=fromSearch
      its the 700r4 package kit
      65ss chevelle
      63ss nova
      3:73
